OnePlus 8T Screen Replacement
Выберете то, что вам нужно
  1. OnePlus 8T Screen Replacement, Step 1  Remove the SIM tray: шаг 1, изображение 1 из 1
    • Before you begin, switch off your phone
    • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the bottom right edge of the phone.
    • Press firmly to eject the tray
    • Remove sim card tray
    Спросите у FixBot
    Добавить комментарий
  2. OnePlus 8T Screen Replacement, Heat the rear glass: шаг 2, изображение 1 из 1
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    Спросите у FixBot
  3. OnePlus 8T Screen Replacement, Create a gap: шаг 3, изображение 1 из 3 OnePlus 8T Screen Replacement, Create a gap: шаг 3, изображение 2 из 3 OnePlus 8T Screen Replacement, Create a gap: шаг 3, изображение 3 из 3
    • Apply a suction cup to the back of the phone, as close as possible to the center of the bottom edge.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert the tip of an opening pick into the gap and slide it to the bottom left corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    Спросите у FixBot
  4. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 4, изображение 1 из 2 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 4, изображение 2 из 2
    • Insert a second opening under the bottom left corner.
    • Slide the opening pick along the bottom edge to the bottom right corner.
    • Leave the pick in its place to prevent the adhesive from resealing.
    Спросите у FixBot
  5. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 5, изображение 1 из 3 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 5, изображение 2 из 3 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 5, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick under the bottom right corner.
    • Slide the opening pick along the right edge to the top right corner.
    • Leave the opening picks in their place to prevent the adhesive from resealing.
    Спросите у FixBot
  6. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 6, изображение 1 из 2 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 6, изображение 2 из 2
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the top left corner to cut the adhesive.
    Спросите у FixBot
  7. OnePlus 8T Screen Replacement, Slice the remaining adhesive: шаг 7, изображение 1 из 3 OnePlus 8T Screen Replacement, Slice the remaining adhesive: шаг 7, изображение 2 из 3 OnePlus 8T Screen Replacement, Slice the remaining adhesive: шаг 7, изображение 3 из 3
    • Insert a fifth opening pick under the top left corner.
    • Slide the opening pick along the left edge to the bottom left corner to cut the remaining adhesive.
    Спросите у FixBot
  8. OnePlus 8T Screen Replacement, Remove the rear glass: шаг 8, изображение 1 из 1
    • Remove the rear glass.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Спросите у FixBot
  9. OnePlus 8T Screen Replacement, Unscrew the motherboard cover: шаг 9, изображение 1 из 1
    • Use a Phillips screwdriver to remove the nine 3.8 mm-long screws securing the motherboard cover.
    Спросите у FixBot
  10. OnePlus 8T Screen Replacement, Unclip the motherboard cover: шаг 10, изображение 1 из 3 OnePlus 8T Screen Replacement, Unclip the motherboard cover: шаг 10, изображение 2 из 3 OnePlus 8T Screen Replacement, Unclip the motherboard cover: шаг 10, изображение 3 из 3
    • Insert the tip of an opening pick under the bottom left corner of the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that hold it in place.
    Спросите у FixBot
  11. OnePlus 8T Screen Replacement, Remove the motherboard cover: шаг 11, изображение 1 из 1
    • Remove the motherboard cover.
    Спросите у FixBot
  12. OnePlus 8T Screen Replacement, Disconnect the battery: шаг 12, изображение 1 из 2 OnePlus 8T Screen Replacement, Disconnect the battery: шаг 12, изображение 2 из 2
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
    Спросите у FixBot
  13. OnePlus 8T Screen Replacement, Unscrew the daughterboard cover: шаг 13, изображение 1 из 1
    • Use a Phillips screwdriver to remove the seven 3.8 mm-long screws securing the daughterboard cover.
    Спросите у FixBot
  14. OnePlus 8T Screen Replacement, Remove the daughterboard cover: шаг 14, изображение 1 из 3 OnePlus 8T Screen Replacement, Remove the daughterboard cover: шаг 14, изображение 2 из 3 OnePlus 8T Screen Replacement, Remove the daughterboard cover: шаг 14, изображение 3 из 3
    • Insert the tip of an opening pick under the top edge of the daughterboard cover.
    • Remove the daughterboard cover.
    Спросите у FixBot
  15. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: шаг 15, изображение 1 из 2 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: шаг 15, изображение 2 из 2
    • Use a spudger to disconnect the first fingerprint sensor connector by prying it straight up from its socket.
    Спросите у FixBot
  16. OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: шаг 16, изображение 1 из 2 OnePlus 8T Screen Replacement, Disconnect the fingerprint sensor: шаг 16, изображение 2 из 2
    • Use a spudger to disconnect the second fingerprint sensor connector by prying it straight up from its socket.
    Спросите у FixBot
  17. OnePlus 8T Screen Replacement, Disconnect the interconnect cable: шаг 17, изображение 1 из 2 OnePlus 8T Screen Replacement, Disconnect the interconnect cable: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
    Спросите у FixBot
  18. OnePlus 8T Screen Replacement, Disconnect the antenna cables: шаг 18, изображение 1 из 3 OnePlus 8T Screen Replacement, Disconnect the antenna cables: шаг 18, изображение 2 из 3 OnePlus 8T Screen Replacement, Disconnect the antenna cables: шаг 18, изображение 3 из 3
    • Carefully disconnect the two antenna cables by prying them straight up from the daughterboard.
    Спросите у FixBot
  19. OnePlus 8T Screen Replacement, Unscrew the daughterboard: шаг 19, изображение 1 из 1
    • Use a Phillips screwdriver to remove the 3.1 mm-long screw securing the daughterboard.
    Спросите у FixBot
  20. OnePlus 8T Screen Replacement, Separate the daughterboard: шаг 20, изображение 1 из 2 OnePlus 8T Screen Replacement, Separate the daughterboard: шаг 20, изображение 2 из 2
    • Use an opening pick to pry up the daughterboard.
    • Use your fingers to separate the daughterboard from the phone assembly.
    Спросите у FixBot
  21. OnePlus 8T Screen Replacement, Disconnect the screen: шаг 21, изображение 1 из 2 OnePlus 8T Screen Replacement, Disconnect the screen: шаг 21, изображение 2 из 2
    • Use the flat edge of a spudger to pry up and disconnect the screen connector from its socket at the frame.
    Спросите у FixBot
  22. OnePlus 8T Screen Replacement, Heat the screen: шаг 22, изображение 1 из 1
    • Heat an iOpener and apply it to the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Спросите у FixBot
  23. OnePlus 8T Screen Replacement, Create a gap: шаг 23, изображение 1 из 2 OnePlus 8T Screen Replacement, Create a gap: шаг 23, изображение 2 из 2
    • Apply a suction cup to the right edge of the screen.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull the suction cup up with strong, steady force to create a gap.
    • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
    Спросите у FixBot
  24. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 24, изображение 1 из 3 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 24, изображение 2 из 3 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 24, изображение 3 из 3
    • Insert a second opening pick at the bottom right corner.
    • Leave both opening picks in their place to prevent the adhesive from resealing.
    Спросите у FixBot
  25. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 25, изображение 1 из 2 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 25, изображение 2 из 2
    • Slide the opening pick along the bottom edge to the bottom left corner to slice the adhesive.
    • Leave the pick in its place to prevent then adhesive from resealing.
    Спросите у FixBot
  26. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 26, изображение 1 из 3 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 26, изображение 2 из 3 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 26, изображение 3 из 3
    • Insert a fourth opening pick under the bottom left corner.
    • Slide the opening pick along the left edge to the top left corner to slice the adhesive.
    Спросите у FixBot
  27. OnePlus 8T Screen Replacement, Slice the adhesive: шаг 27, изображение 1 из 2 OnePlus 8T Screen Replacement, Slice the adhesive: шаг 27, изображение 2 из 2
    • Slide the opening pick along the top edge to the top right corner.
    • When you slice near the front facing camera, insert only the tip (5 mm) of the opening pick to avoid damaging the camera.
    • Do not remove the screen completely yet. The display cable is still threaded through the midframe.
    Спросите у FixBot
  28. OnePlus 8T Screen Replacement, Separate the screen: шаг 28, изображение 1 из 2 OnePlus 8T Screen Replacement, Separate the screen: шаг 28, изображение 2 из 2
    • Thread the display flex cable through the gap in the frame.
    Спросите у FixBot
  29. OnePlus 8T Screen Replacement, Remove the screen: шаг 29, изображение 1 из 1
    • Remove the screen.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
    Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
11 человек успешно провели ремонт по этому руководству.
Adriana Zwink
Участник с: 12/18/19
67 365 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
122 членов
Автор 26 511 руководств
6 Комментарии к руководству
Thank you iFixit & Adriana! These intructions are spot on and guided me perfectly through a successful front and rear screen replacement.
Jim M.
Jim Malinak - Ответить Поделиться
Hi Jim, we're happy to hear that we were able to help you with your repair!
Adriana Zwink - Ответить Поделиться
I broke my phone one plus 8T just now, how should i proceed next ? I want it really to be fixed but not sure if its still in a condition that i can be repaired
Akshay Raina - Ответить Поделиться
Do you remove the front earpiece speaker grill as well when you remove the front screen? As I am putting the screen back on, not sure if the top of the screen needs to be under the grill, but for some reason, it isn't matching or it's bulging from that area.
Erik Stejanko - Ответить Поделиться
WARNING!
You have to remove the sim card tray before removing the daughterboard. At nno point in this guide is this mentioned. You risk damaging the daughterboard when trying to pry it loose.
Staffan Näs - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 63
За последние 30 дней: 296
За всё время: 33,165
