Opening Procedure
Выберете то, что вам нужно
    1. Opening Procedure, Power down the watch: шаг 1, изображение 1 из 2 Opening Procedure, Power down the watch: шаг 1, изображение 2 из 2
      Спросите у FixBot
      Добавить комментарий
    2. Opening Procedure, Safety Requirements: шаг 2, изображение 1 из 3 Opening Procedure, Safety Requirements: шаг 2, изображение 2 из 3 Opening Procedure, Safety Requirements: шаг 2, изображение 3 из 3
      • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
      • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
      • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
      • Wear eye protection. The knife or glass may break, sending pieces flying.
      • Attach or remove the watch band as needed to provide more control as you make repairs.
      Спросите у FixBot
    3. Opening Procedure, Soften the display adhesive: шаг 3, изображение 1 из 1
      • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
      • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
      • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
      Спросите у FixBot
    4. Opening Procedure, Display opening: шаг 4, изображение 1 из 3 Opening Procedure, Display opening: шаг 4, изображение 2 из 3 Opening Procedure, Display opening: шаг 4, изображение 3 из 3
      • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
      • Press firmly straight down into the gap.
      • Once inserted, tilt the blade to pry the display open slightly.
      Спросите у FixBot
    5. Opening Procedure: шаг 5, изображение 1 из 3 Opening Procedure: шаг 5, изображение 2 из 3 Opening Procedure: шаг 5, изображение 3 из 3
      • Insert an opening pick in the gap your created.
      • Slide the opening pick along the short edge of the watch to cut the adhesive.
      Спросите у FixBot
    6. Opening Procedure: шаг 6, изображение 1 из 2 Opening Procedure: шаг 6, изображение 2 из 2
      • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to cut the display adhesive.
      Спросите у FixBot
    7. Opening Procedure: шаг 7, изображение 1 из 2 Opening Procedure: шаг 7, изображение 2 из 2
      • Slide the opening pick around the corner to cut the remaining adhesive on the short edge of the watch next to the watch crown.
      Спросите у FixBot
    8. Opening Procedure: шаг 8, изображение 1 из 2 Opening Procedure: шаг 8, изображение 2 из 2
      • Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
      • Try not to slice near the watch crown to prevent damaging the display cables. If you must slice near the crown, don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
      • Slide an opening pick under the opposite display edge of the watch crown.
      • Twist the opening pick to loosen the display off the watch case.
      • Don't try to remove the display. It is still connected to the watch assembly.
      Спросите у FixBot
    9. Opening Procedure: шаг 9, изображение 1 из 3 Opening Procedure: шаг 9, изображение 2 из 3 Opening Procedure: шаг 9, изображение 3 из 3
      • Be careful not to strain the display cables when you fold the display to the side.
      • Lift the display and carefully pull it towards the watch crown.
      • Swing the display open to an upward position.
      Спросите у FixBot
Заключение
To reassemble your Apple Watch Series 6, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
6 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
262 916 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 63 470 руководств
2 Комментарии к руководству
Where are the instructions for installing the new adhesive? Also, it's not listed in the tools/parts list.
Joseph Wisniewski - Ответить Поделиться
Here's the guide for resealing the watch
How to Reseal an Apple Watch
TurianSniper - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 33
За последние 30 дней: 143
За всё время: 8,039
