Samsung Galaxy S II Micro-USB Port Replacement
Введение
Перейти к шагу 1Does your phone not charge? Does the battery die quickly, no matter how long it stays on the charger? It could be a sign that a connection has come loose or that the port has been damaged. Replacing it could solve your problem.
Note that there are several different models of the S2 but this guide should help whether you have an international version of the phone or not.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
1. Remove the rear casing and the battery.
2. Remove the SD card and the sim card (if needed).
Use the Phillips screwdriver to remove the 7 Phillips head screws, indicated in the picture.
Move along the outside edge with the plastic tool, popping the connections to the phone.
Remove the two black Phillips head screws located at the top left and the bottom right of the logic board.
Disconnect all push connectors and the antenna cable with a small pull shown on the left.
Prop the motherboard on the side of the phone. Then take off the power button board (near the top of the antenna wire).
Remove the 2 Phillips head screws located at the bottom of the charging board.
21 человек успешно провели ремонт по этому руководству.
6 Комментариев
Hi all,
I have a Samsung Galaxy S2. The USB charging port is not working reliably. I read this repair guide, got the part, and set about replacing the USB charging board. Unfortunately, when I opened the phone, it does not look like the photos in this guide. To start, there are six screws instead of seven. Then when the back is removed, there are not "two black screws" to be removed. Finally, the motherboard is completely different from what is shown here. It is one single board, with the USB charging port board incorporated. It cannot be removed to replace it. So the part I bought does not work with my Samsung Galaxy S2. Is there another guide to help with my model of this phone?
Model SGH-T989
Many thanks.
Hi rileybk, there are quite a number of phones called "Samsung Galaxy S2". Have a look at the Wikipedia here: https://en.wikipedia.org/wiki/Samsung_Ga...
The device shown here seems to be a SGH-I777 which you can read on the label below the battery.
As Wikipedia describes these devices can be very different from each other so that your replacement part might not fit or work at all.
(btw, I came by to look for a guide for the so-called "international version" i9100 ... I have to see whether this guide will help me nethertheless)
Steffan -
