Введение
Follow this guide to replace the front-facing camera module for the Galaxy S20 Plus.
The removal of the camera module is tricky and may result in the destruction of the module. If you plan on reusing the camera module, take care and heed all warnings carefully.
You'll need replacement adhesive in order to complete this repair.
Выберете то, что вам нужно
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave your opening pick in the seam to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
Инструмент, используемый на этом этапе:Tweezers$4.99
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
Gently tilt up the motherboard bracket so the orange battery connector is accessible.
Use a spudger to pry up and disconnect the battery connector.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
Use a Phillips #00 screwdriver to remove the three 4 mm-long screws securing the upper midframe.
Insert the pointed end of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it in place.
Remove the upper midframe.
Use a spudger to pry up and disconnect the front-facing camera flex cable from the motherboard.
Apply high concentration (over 90%) isopropyl alcohol to the gaps around the front-facing camera module to help soften the adhesive securing it into place.
Allow the alcohol 1-2 minutes to penetrate the adhesive.
Use the flat end of a spudger to pry up bottom edge of the front-facing camera module.
Remove the front-facing camera module.
If you removed the camera module's internal components without its plastic casing, apply a few drops of high concentration (over 90%) isopropyl alcohol around the edges of the casing to soften the adhesive securing it into place.
Use a pair of tweezers to remove the plastic camera casing.
After you've completed the repair, follow this guide to test your repair.
Еще один человек закончил это руководство.
