Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Samsung Galaxy Tab A Digitizer Replacement
Michael Wozny
Michael Wozny и 5 другие участники
Последнее обновление October 9, 2024
15 мин.
Средне
A touchscreen that is broken or damaged can prevent access to applications on a device, which can make the device useless. This guide highlights how to remove the back cover and front cover of the tablet in order to get to the touchscreen as a means to replace it.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
  1. Samsung Galaxy Tab A Digitizer Replacement, Digitizer: шаг 1, изображение 1 из 1
    • Make sure the device is turned off before attempting to disassemble it.
    • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
    • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
  2. Samsung Galaxy Tab A Digitizer Replacement: шаг 2, изображение 1 из 2 Samsung Galaxy Tab A Digitizer Replacement: шаг 2, изображение 2 из 2
    • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
    • The second picture shows the internal portion of the device once the back cover is removed.
  3. Samsung Galaxy Tab A Digitizer Replacement: шаг 3, изображение 1 из 2 Samsung Galaxy Tab A Digitizer Replacement: шаг 3, изображение 2 из 2
    • Use the spudger to disconnect the touchscreen from the motherboard. The two are connected at the top half of the motherboard where the yellow rubber portion of the touchscreen is located.
    • The first and second pictures illustrate the touchscreen when it connected and disconnected, respectively.
  4. Samsung Galaxy Tab A Digitizer Replacement: шаг 4, изображение 1 из 2 Samsung Galaxy Tab A Digitizer Replacement: шаг 4, изображение 2 из 2
    • Use the spudger to separate the touch screen from the front cover of the device.
    • The touch screen is glued onto the front cover, so this step in the process requires patience and a fair amount of strength.
    • The top and bottom portions of the touch screen are more reinforced with glue than the other sections, so extra force will be required.
    • It is recommended to push inwards from the sides using the spudger to separate the top and bottom section from the front cover.
  5. Samsung Galaxy Tab A Digitizer Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy Tab A Digitizer Replacement: шаг 5, изображение 2 из 2
    • Once the touchscreen is loose enough, slowly pull it off the front cover to fully remove it from the rest of the device.
    • Avoid pulling the touchscreen off too quickly as this could result in damaging or even breaking the touchscreen. This could result in damaging the touchscreen connector in the back of the device.
    • The picture shows what the device should look like once the touchscreen is fully removed.
Заключение
39 человек успешно провели ремонт по этому руководству.
Michael Wozny
Участник с: 02/04/16
3 717 Репутация
Автор 5 руководств
Команду
USF Tampa, Team 17-4, Blackwell Winter 2016 Участник USF Tampa, Team 17-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G4
4 членов
Автор 12 руководств
13 Комментариев
These steps worked well but you must use a metal spudger to get this started. I didn't have one and it was a nightmare. I finished the project but it was very difficult to start. I would also use a heat gun to loosen the glue for the bottom and top. Just my opinion from my experience.
lasthager - Ответить
See comments on the last step re: avoiding the area of the flex connector, and using heat, as the previous commenter suggested, throughout the removal process to loosen the adhesive and avoid breaking the glass.
Also, the “metal" frame around the digitizer is very susceptible to being dented. Be very careful of it.
Finally, a piece of advice from other iFixit commenters about cleaning the LCD before adding new glass: careful circular motions with a very clean, dry microfiber cloth are sufficient in most cases. If not, a small amount of water can be added to the cloth. Avoid adding alcohol or water directly to the LCD, as it is easily smudged.
Bonnie Baxter - Ответить
^This! An iOpener or heat is a MUST when separating the digitizer and LCD. There is no way the digitizer just pops off. This is especially important if the digitizer is cracked and spider-webbed.
Jeana Morales -
Oops--one final suggestion, also from other iFixit commenters (I can't find the original, or I’d reference it. It's in the Q&A section, answering a question about jumpy digitizer responses after screen replacement.)
The first time I did this, all seemed well until I tried to use the digitizer, when its response to touch was suddenly very jumpy and erratic in all areas of the screen. The next time I followed Ifixit advice and covered all metallic-looking areas of the back of the new screen with thin Kapton tape, and had no problems. I essentially made a thin frame of Kapton all the way around the non-transparent areas of the screen.
There have been various suggestions about why this might work, most speculating on small electrical shorts occurring between these metallic areas and the metal parts of the frame surrounding the LCD. I just know that it's quick and easy and seems to work.
Hi Bonnie, would you happen to know what thickness of tape that should be? I’m getting little to no response then when I put the back on i’m getting nothing at all.
freeaswind -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 23
За последние 30 дней: 88
За всё время: 33,709
