Samsung Watch Active Screen Assembly Replacement
Выберете то, что вам нужно
    1. Samsung Watch Active Screen Assembly Replacement, Turn off the watch: шаг 1, изображение 1 из 2 Samsung Watch Active Screen Assembly Replacement, Turn off the watch: шаг 1, изображение 2 из 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Watch Active Screen Assembly Replacement, Remove the rear screws: шаг 2, изображение 1 из 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Спросите у FixBot
    3. Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: шаг 3, изображение 1 из 3 Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: шаг 3, изображение 2 из 3 Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: шаг 3, изображение 3 из 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Спросите у FixBot
    4. Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: шаг 4, изображение 1 из 2 Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: шаг 4, изображение 2 из 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Спросите у FixBot
    5. Samsung Watch Active Screen Assembly Replacement, Remove the back cover: шаг 5, изображение 1 из 1
      • Remove the back cover.
      Спросите у FixBot
    1. Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: шаг 6, изображение 1 из 3 Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: шаг 6, изображение 2 из 3 Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: шаг 6, изображение 3 из 3
      • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
      Спросите у FixBot
    2. Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: шаг 7, изображение 1 из 3 Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: шаг 7, изображение 2 из 3 Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: шаг 7, изображение 3 из 3
      • Use an opening pick to peel back the thin tape belonging to the microphone array.
      • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
      Спросите у FixBot
    3. Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: шаг 8, изображение 1 из 2 Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: шаг 8, изображение 2 из 2
      • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
      Спросите у FixBot
    4. Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: шаг 9, изображение 1 из 3 Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: шаг 9, изображение 2 из 3 Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: шаг 9, изображение 3 из 3
      • Lift out and remove the core assembly.
      Спросите у FixBot
    1. Samsung Watch Active Screen Assembly Replacement, Loosen the mic: шаг 10, изображение 1 из 2 Samsung Watch Active Screen Assembly Replacement, Loosen the mic: шаг 10, изображение 2 из 2
      • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
      Спросите у FixBot
    2. Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: шаг 11, изображение 1 из 2 Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: шаг 11, изображение 2 из 2
      • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
      Спросите у FixBot
    3. Samsung Watch Active Screen Assembly Replacement, Remove the mic array: шаг 12, изображение 1 из 1
      • Carefully remove the microphone and barometric sensor array from the frame.
      Спросите у FixBot
    1. Samsung Watch Active Screen Assembly Replacement, Screen Assembly: шаг 13, изображение 1 из 1
      • You’re left with the screen assembly.
      • Make sure to compare the new screen assembly to the old one for any parts that need to be transferred.
      Спросите у FixBot
Заключение
17 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
134 915 Репутация
Автор 189 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 596 руководств
13 Комментарии к руководству
These instructions look very good! My screen has several cracks and I want to replace the front module. Do you have any idea where I can order one?
Jantine Stulp - Ответить Поделиться
My screen was black or showing static. I disassembled and reassembled and now it's back to normal. Might have been a bad internal connection.
Benjamin Franzmayr - Ответить Поделиться
Think I have the same issue may have to try opening it. Do you still have it? Is it still good?
Simon Hall - Ответить Поделиться
this is a rather silly question, but which model is that diode on the LCD panel? I couldn't find the schematics for the screen
Thomas Jungblut - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 19
За последние 30 дней: 122
За всё время: 18,509
