Samsung Watch Active Screen Replacement
Выберете то, что вам нужно
    1. Samsung Watch Active Screen Replacement, Turn off the watch: шаг 1, изображение 1 из 2 Samsung Watch Active Screen Replacement, Turn off the watch: шаг 1, изображение 2 из 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Watch Active Screen Replacement, Remove the rear screws: шаг 2, изображение 1 из 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Спросите у FixBot
    3. Samsung Watch Active Screen Replacement, Separate the back cover from the housing: шаг 3, изображение 1 из 3 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: шаг 3, изображение 2 из 3 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: шаг 3, изображение 3 из 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Спросите у FixBot
    4. Samsung Watch Active Screen Replacement, Disconnect the sensor array: шаг 4, изображение 1 из 2 Samsung Watch Active Screen Replacement, Disconnect the sensor array: шаг 4, изображение 2 из 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Спросите у FixBot
    5. Samsung Watch Active Screen Replacement, Remove the back cover: шаг 5, изображение 1 из 1
      • Remove the back cover.
      Спросите у FixBot
    1. Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: шаг 6, изображение 1 из 3 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: шаг 6, изображение 2 из 3 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: шаг 6, изображение 3 из 3
      • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
      Спросите у FixBot
    2. Samsung Watch Active Screen Replacement, Undo the mic tape: шаг 7, изображение 1 из 3 Samsung Watch Active Screen Replacement, Undo the mic tape: шаг 7, изображение 2 из 3 Samsung Watch Active Screen Replacement, Undo the mic tape: шаг 7, изображение 3 из 3
      • Use an opening pick to peel back the thin tape belonging to the microphone array.
      • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
      Спросите у FixBot
    3. Samsung Watch Active Screen Replacement, Lift the core assembly: шаг 8, изображение 1 из 2 Samsung Watch Active Screen Replacement, Lift the core assembly: шаг 8, изображение 2 из 2
      • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
      Спросите у FixBot
    4. Samsung Watch Active Screen Replacement, Remove the core assembly: шаг 9, изображение 1 из 3 Samsung Watch Active Screen Replacement, Remove the core assembly: шаг 9, изображение 2 из 3 Samsung Watch Active Screen Replacement, Remove the core assembly: шаг 9, изображение 3 из 3
      • Lift out and remove the core assembly.
      Спросите у FixBot
    1. Samsung Watch Active Screen Replacement, Loosen the mic: шаг 10, изображение 1 из 2 Samsung Watch Active Screen Replacement, Loosen the mic: шаг 10, изображение 2 из 2
      • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
      Спросите у FixBot
    2. Samsung Watch Active Screen Replacement, Free the barometric sensor: шаг 11, изображение 1 из 2 Samsung Watch Active Screen Replacement, Free the barometric sensor: шаг 11, изображение 2 из 2
      • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
      Спросите у FixBot
    3. Samsung Watch Active Screen Replacement, Remove the mic array: шаг 12, изображение 1 из 1
      • Carefully remove the microphone and barometric sensor array from the frame.
      Спросите у FixBot
    1. Samsung Watch Active Screen Replacement, Loosen the screen adhesive: шаг 13, изображение 1 из 1
      Спросите у FixBot
    2. Samsung Watch Active Screen Replacement, Separate the screen and frame: шаг 14, изображение 1 из 3 Samsung Watch Active Screen Replacement, Separate the screen and frame: шаг 14, изображение 2 из 3 Samsung Watch Active Screen Replacement, Separate the screen and frame: шаг 14, изображение 3 из 3
      • Insert the opening tool under the frame where the sensor array was located.
      • Pry upwards to separate the screen from the frame.
      Спросите у FixBot
    3. Samsung Watch Active Screen Replacement, Remove the screen: шаг 15, изображение 1 из 3 Samsung Watch Active Screen Replacement, Remove the screen: шаг 15, изображение 2 из 3 Samsung Watch Active Screen Replacement, Remove the screen: шаг 15, изображение 3 из 3
      • Use your fingers to pull the frame off the remaining screen adhesive.
      • Clean any remaining adhesive from the frame using isopropyl alcohol (>90%) before installing the new screen.
      Спросите у FixBot
Заключение
5 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
134 915 Репутация
Автор 189 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 600 руководств
3 Комментарии к руководству
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Rosalie E. Morgan - Ответить Поделиться
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
Colm O'Sullivan - Ответить Поделиться
How do I put the mic array back in?
Mason Thomas - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 39
За последние 30 дней: 150
За всё время: 6,702
