Smart Soldering Iron Main Board Replacement
Выберете то, что вам нужно
  1. Smart Soldering Iron Main Board Replacement, How to read the Touch-Safe Indicator LED: шаг 1, изображение 1 из 3 Smart Soldering Iron Main Board Replacement, How to read the Touch-Safe Indicator LED: шаг 1, изображение 2 из 3 Smart Soldering Iron Main Board Replacement, How to read the Touch-Safe Indicator LED: шаг 1, изображение 3 из 3
    • The color of the Touch-Safe Indicator LED provides information about the status of the soldering iron tip. Note: the soldering iron grip is always safe to touch.
    • The LED only functions when the soldering iron is connected to a power source—so use caution when handling an unplugged iron if you don't know how hot it is.
    • Blue LED: The iron has cooled below 40 °C (100 °F), and the tip is safe to touch.
    • Purple LED: When pulsing, the iron is actively heating up or cooling down. When static, the iron is in Idle Mode. The iron tip is not safe to touch.
    • Orange LED: The iron has reached the set temperature and is ready to solder. The iron tip is not safe to touch.
    Спросите у FixBot
    Добавить комментарий
  2. Smart Soldering Iron Main Board Replacement, Turn off the iron: шаг 2, изображение 1 из 3 Smart Soldering Iron Main Board Replacement, Turn off the iron: шаг 2, изображение 2 из 3 Smart Soldering Iron Main Board Replacement, Turn off the iron: шаг 2, изображение 3 из 3
    • The sliding power switch has a built-in color indicator for each position:
    • Orange: ON
    • Blue: OFF
    • Slide the power switch to the blue OFF position.
    • The LED will turn purple and pulse to show the iron is powering down.
    • Leave the soldering iron connected until the indicator ring turns blue, indicating it's now safe to touch the soldering iron tip.
    • Remember: The LED only functions when the soldering iron is connected to a power source—so use caution when handling an unplugged iron if you don't know how hot it is.
    Спросите у FixBot
  3. Smart Soldering Iron Main Board Replacement, Unplug the iron: шаг 3, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Unplug the iron: шаг 3, изображение 2 из 2
    • Disconnect the iron's USB-C cable from your power source.
    Спросите у FixBot
  4. Smart Soldering Iron Main Board Replacement, Unlock the locking collar: шаг 4, изображение 1 из 3 Smart Soldering Iron Main Board Replacement, Unlock the locking collar: шаг 4, изображение 2 из 3 Smart Soldering Iron Main Board Replacement, Unlock the locking collar: шаг 4, изображение 3 из 3
    • Twist the blue cable collar counter-clockwise and pull up to release it from the iron.
    Спросите у FixBot
  5. Smart Soldering Iron Main Board Replacement, Disconnect the cable from the iron: шаг 5, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Disconnect the cable from the iron: шаг 5, изображение 2 из 2
    • Disconnect the USB-C cable from the Smart Soldering Iron.
    Спросите у FixBot
  6. Smart Soldering Iron Main Board Replacement, Remove the soldering iron cap: шаг 6, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Remove the soldering iron cap: шаг 6, изображение 2 из 2
    • Hold the iron from both ends and pull to remove the cap.
    Спросите у FixBot
  7. Smart Soldering Iron Main Board Replacement, Remove the quick-swap soldering tip: шаг 7, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Remove the quick-swap soldering tip: шаг 7, изображение 2 из 2
    • Make sure the tip has fully cooled before touching it.
    • Firmly grasp the base of the tip and pull it away from the front of the iron handle to remove it.
    Спросите у FixBot
  8. Smart Soldering Iron Main Board Replacement, Remove the handle screws: шаг 8, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Remove the handle screws: шаг 8, изображение 2 из 2
    • Use a Phillips screwdriver to remove the three blue 3.4 mm‑long screws securing the blue end cap.
    • Use a Phillips screwdriver to remove the one black 3.4 mm‑long screw at the base of the enclosure.
    Спросите у FixBot
  9. Smart Soldering Iron Main Board Replacement, Remove the blue end cap: шаг 9, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Remove the blue end cap: шаг 9, изображение 2 из 2
    • Pull to remove the blue end cap from the rest of the iron handle.
    Спросите у FixBot
  10. Smart Soldering Iron Main Board Replacement, Remove the power switch: шаг 10, изображение 1 из 2 Smart Soldering Iron Main Board Replacement, Remove the power switch: шаг 10, изображение 2 из 2
    • Remove the blue and orange power switch.
    Спросите у FixBot
  11. Smart Soldering Iron Main Board Replacement, Remove the main board: шаг 11, изображение 1 из 3 Smart Soldering Iron Main Board Replacement, Remove the main board: шаг 11, изображение 2 из 3 Smart Soldering Iron Main Board Replacement, Remove the main board: шаг 11, изображение 3 из 3
    • Grasp the end of the main board that sticks out from inside of the soldering iron handle.
    • Pull to slide the main board out of the handle.
    • When reassembling your iron, make sure to insert the main board with the shiny iron auxiliary port end first.
    Спросите у FixBot
Заключение
To reassemble your Smart Soldering Iron, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Kara Piepenbrink
Участник с: 05/31/24
8 227 Репутация
Автор 21 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 230 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 65
За всё время: 1,596
