Sony Cyber-shot DSC-T500 Front Panel Replacement
Введение
Перейти к шагу 1This simple 2 step guide will show you how to remove the front panel in order to maintain or replace it.
Выберете то, что вам нужно
Инструменты
Remove all seven black 4 mm Philips #00 screws holding the front panel into place. Two on each of the sides of the camera and three on the bottom.
Gently lift the front panel up off the back of the camera prying up around the edges using a plastic opening tool or spudger if necessary.
