Steam Deck OLED Screen Replacement
Выберете то, что вам нужно
  1. Steam Deck OLED Screen Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 1 из 2 Steam Deck OLED Screen Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 2 из 2
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
  2. Steam Deck OLED Screen Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 Steam Deck OLED Screen Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 Steam Deck OLED Screen Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Ответить
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Ответить
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Ответить
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Ответить
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Ответить
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Ответить
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Ответить
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Ответить
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Ответить
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Ответить
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Ответить
  3. Steam Deck OLED Screen Replacement, Heat the top edge screen adhesive: шаг 3, изображение 1 из 1
    • Prepare an iOpener and apply it to the top edge of the screen for one minute.
    • You may also use a hair dryer or heat gun, but be careful not to overheat the device, as the screen, battery, and plastic frame are all susceptible to heat damage.
  4. Steam Deck OLED Screen Replacement, Apply a suction handle: шаг 4, изображение 1 из 2 Steam Deck OLED Screen Replacement, Apply a suction handle: шаг 4, изображение 2 из 2
    • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
  5. Steam Deck OLED Screen Replacement, Insert an opening pick: шаг 5, изображение 1 из 3 Steam Deck OLED Screen Replacement, Insert an opening pick: шаг 5, изображение 2 из 3 Steam Deck OLED Screen Replacement, Insert an opening pick: шаг 5, изображение 3 из 3
    • Pull up on the suction handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the screen panel, ambient light sensor, or sensor cable.
  6. Steam Deck OLED Screen Replacement, Remove the suction handle: шаг 6, изображение 1 из 2 Steam Deck OLED Screen Replacement, Remove the suction handle: шаг 6, изображение 2 из 2
    • Pull up on the nub on the back of the suction handle to remove it from the screen.
  7. Steam Deck OLED Screen Replacement, Screen information: шаг 7, изображение 1 из 3 Steam Deck OLED Screen Replacement, Screen information: шаг 7, изображение 2 из 3 Steam Deck OLED Screen Replacement, Screen information: шаг 7, изображение 3 из 3
    • As you slice through the adhesive securing the screen, note the following:
    • Along the top and bottom edges, don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the sensors, sensors cable, or screen cable.
    • Along the left and right edges, don't insert your pick deeper than 5 mm (~1/5 of an inch) to avoid damaging the screen panel.
  8. Steam Deck OLED Screen Replacement, Reposition the pick: шаг 8, изображение 1 из 3 Steam Deck OLED Screen Replacement, Reposition the pick: шаг 8, изображение 2 из 3 Steam Deck OLED Screen Replacement, Reposition the pick: шаг 8, изображение 3 из 3
    • Rotate the pick so its flat edge is between the screen and frame.
    • Leave this pick inserted to prevent the adhesive from resealing.
  9. Steam Deck OLED Screen Replacement, Separate the top edge adhesive: шаг 9, изображение 1 из 3 Steam Deck OLED Screen Replacement, Separate the top edge adhesive: шаг 9, изображение 2 из 3 Steam Deck OLED Screen Replacement, Separate the top edge adhesive: шаг 9, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the top edge.
    • Insert another pick in the top left corner.
    • Slide the pick toward the power button to separate the adhesive securing the top edge of the screen.
  10. Steam Deck OLED Screen Replacement, Reposition the pick: шаг 10, изображение 1 из 3 Steam Deck OLED Screen Replacement, Reposition the pick: шаг 10, изображение 2 из 3 Steam Deck OLED Screen Replacement, Reposition the pick: шаг 10, изображение 3 из 3
  11. Steam Deck OLED Screen Replacement, Heat the right edge screen adhesive: шаг 11, изображение 1 из 1
    • Heat the right edge of the screen for one minute.
  12. Steam Deck OLED Screen Replacement, Separate the right edge adhesive: шаг 12, изображение 1 из 2 Steam Deck OLED Screen Replacement, Separate the right edge adhesive: шаг 12, изображение 2 из 2
    • Don't insert your pick deeper than 5 mm (~1/5 of an inch) along the right edge.
    • Insert another pick just below the right thumbstick.
    • Slide the pick to the bottom right corner to separate the right edge adhesive.
    • Leave the pick inserted to prevent the adhesive from resealing.
  13. Steam Deck OLED Screen Replacement, Heat the bottom edge adhesive: шаг 13, изображение 1 из 1
    • Heat the bottom edge of the screen for one minute.
  14. Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: шаг 14, изображение 1 из 3 Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: шаг 14, изображение 2 из 3 Steam Deck OLED Screen Replacement, Separate the bottom edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the bottom edge.
    • Insert another pick in bottom right corner along the bottom edge.
    • Slide the pick to the bottom left corner to separate the bottom edge adhesive.
  15. Steam Deck OLED Screen Replacement, Lift the top edge of the screen: шаг 15, изображение 1 из 3 Steam Deck OLED Screen Replacement, Lift the top edge of the screen: шаг 15, изображение 2 из 3 Steam Deck OLED Screen Replacement, Lift the top edge of the screen: шаг 15, изображение 3 из 3
    • Grip the two picks along the top edge.
    • Pry up to lift the top edge of the screen away from the frame until you can grab it.
    • If the screen feels stuck, go back around the perimeter and check for missed sections of adhesive. If you're using a hair dryer, use it to lightly heat the stuck sections of adhesive.
  16. Steam Deck OLED Screen Replacement, Flip the screen over: шаг 16, изображение 1 из 3 Steam Deck OLED Screen Replacement, Flip the screen over: шаг 16, изображение 2 из 3 Steam Deck OLED Screen Replacement, Flip the screen over: шаг 16, изображение 3 из 3
    • Be gentle with the screen, as straining its cable may damage the socket on the motherboard.
    • Flip the screen over the bottom edge of the frame.
    • Prop up the screen with a small box or book roughly 2.5 cm (~1 inch) thick.
    • If you don't have a box or book nearby, hold the screen in this position for the next two steps.
  17. Steam Deck OLED Screen Replacement, Unlatch the screen connector: шаг 17, изображение 1 из 2 Steam Deck OLED Screen Replacement, Unlatch the screen connector: шаг 17, изображение 2 из 2
    • Use the point of a spudger or a clean fingernail to flip up the locking flap on the outside edge of the screen ZIF connector.
    • Don't touch any of the small surface-mounted components around the connector.
  18. Steam Deck OLED Screen Replacement, Disconnect the screen: шаг 18, изображение 1 из 2 Steam Deck OLED Screen Replacement, Disconnect the screen: шаг 18, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use tweezers or your fingers to grip the screen cable pull tab and slide the cable straight out of its socket to disconnect it.
  19. Steam Deck OLED Screen Replacement, Remove the screen: шаг 19, изображение 1 из 1
Заключение
To reapply adhesive and install your screen, follow this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
5 человек успешно провели ремонт по этому руководству.
Clay Eickemeyer
Участник с: 09/19/22
81 853 Репутация
Автор 455 руководств
Команду
Guide Team Участник Guide Team
Staff
9 членов
Автор 11 420 руководств
6 Комментариев
I successfully swapped matte/glossy OLED model screens this way. First boot after swap had a frazzled screen. Hard reset fixed the problem instantly.
keyscameron - Ответить
Is this compatible with limited edition?
Joen Liwanag - Ответить
the steps are the same for both OLED models. However the LE comes stock with a matte screen, standard model with glossy screen
keyscameron -
Is it possible to upgrade Steam Deck 512GB LCD model to better matte OLED screen?
As well as upgrade the WiFi card?
gurenmkd - Ответить
No for the screen, i do not know for wifi. i doubt it.
keyscameron -
Are connectors for screen same in lcd steam deck and oled screen? And possible to connect both with some alternative?
Ferryman charon - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 40
За последние 7 дней: 242
За последние 30 дней: 1,121
За всё время: 19,049
