Введение
Oftentimes, things get stuck in between keys, or keys labels get worn out with use. This guide will assist in replacing that broken keyboard with a new one.
Инструменты
Запчасти
Детали не указаны.
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
Slide the white ribbon connector up and lift the ribbon out of it.
