Инструменты
Запчасти
No parts specified.
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
Use the plastic opening tool to pop off tabs along the length of this panel.
Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
Lift the keyboard gently from the side closest the screen.
Pull out the ribbon connecting the keyboard to the laptop.
Disconnect wire attaching LCD to motherboard
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
Using the pry tool separate the two halves of the laptop base.
Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
