Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Toshiba Satellite A505 series Battery Replacement
Jerry F Nerviano
Jerry F Nerviano и 2 другие участники
Последнее обновление November 12, 2022
1 минут
Очень просто
Руководство, предоставленное сообществом
After unplugging the external power supply, this is the FIRST step in any laptop disassembly where the battery is accessible from the outside.
  1. Toshiba Satellite A505 series Battery Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite A505 series Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the system over and locate the locking switches near the battery.
    • This switch is not spring-loaded. Slide it away from the battery to unlock.
    • This switch IS spring-loaded and will have to be held to release the battery. It slides in the opposite direction of the first switch.
    • The example here shows an after-market high-capacity battery. The procedure is the same, regardless.
Заключение
Follow this procedure in reverse to install the (new) battery. Note that the second switch will engage automatically upon install. The first switch will not and must be locked manually once the battery is in place.
5 человек успешно провели ремонт по этому руководству.
Jerry F Nerviano
Участник с: 11/18/10
2 138 Репутация
1 руководство автора
Команду
Jerry's Computer Service Участник Jerry's Computer Service
Business
1 член
Автор 3 руководств
4 Комментариев
I have a Toshiba statellite click W35Dt-A3300 window 8.1
How do I take and put new battery in ?
eddiecabral32 - Ответить
Have you seen the Toshiba Satellite Click guides? This should be the battery guide you need: Toshiba Satellite Click Tablet Battery Replacement.
Sam Goldheart -
I have a Toshiba A356-S69253 and the battery after a long charge reads 7 - 13 % Charge. On rare occasion I see 97% but within a minute or two the computer shuts down. When I restart the charge is down to 3%. I am having uncontrolled shut down and other problem and suspect a battery problem
The Battery is built in. Can I change the battery? How much is a battery? Can someone else change the battery? How much $? The laptop is pretty old, is it worth trying to fix?
buschwa@aol.com 7/2/2017
buschwa - Ответить
Hvordan tager jeg batteri ud af en Toshiba Satellite L50D-A-10D
Birthe Kirkgaard - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 4,427
