Toshiba Satellite C55-A5310 RAM Replacement
Выберете то, что вам нужно
Push the left tab with your left hand.
Then push the right tab with your right hand.
While your right hand is still pushing, remove the battery with your left hand.
Use the plastic opening tool to pry the panel open. Be sure to do this on all four sides. Then the panel will lift off.
Инструмент, используемый на этом этапе:Tweezers$4.99
Once the RAM has lifted, use tweezers or fingers to pull it out.
