Toshiba Satellite C55-B5200 RAM Replacement
Введение
Перейти к шагу 1How to replace the RAM on a Toshiba Satellite C55-B5200 laptop.
Выберете то, что вам нужно
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Flex the metal retaining clips on the side of the RAM away from one another.
3 человек успешно провели ремонт по этому руководству.
Один комментарий
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
