Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Toshiba Satellite L755D-S5150 Motherboard Replacement
Shaheedah
Shaheedah и 7 другие участники
Последнее обновление September 22, 2023
30 мин. - 1 час
Средне
Usually when people hear that their motherboard needs to be replaced they think that it is the end for their computer. It is something that should be done with care since there are many intricate parts. It's good to have something to put your screws in, too.
Выберете то, что вам нужно
Инструменты
  1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Motherboard Replacement, Keyboard: шаг 2, изображение 1 из 1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
    • Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
    • Slide the ODD outward.
    • Removing the RAM is not necessary
    • The ODD is also commonly referred to as a CD-ROM.
  6. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Use the Phillips PH00 screwdriver to remove one 4mm screw.
    • Use the Phillips PH00 screwdriver to remove the two 3mm screws from the fan.
    • The motherboard will be accessed from below the keyboard, therefore you will not need to take out the bottom of the laptop.
  7. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Use the Phillips PH00 to unscrew the fifteen 4mm screws holding down the motherboard.
  8. Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 8, изображение 1 из 2 Toshiba Satellite L755D-S5150 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Lift the motherboard and disconnect the 4 pin connector on the bottom side.
Заключение
2 человек успешно провели ремонт по этому руководству.
Shaheedah
Участник с: 10/06/16
276 Репутация
Автор 2 руководств
Команду
USF Tampa, Team 2-5, Sullivan Fall 2016 Участник USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 членов
Автор 5 руководств
Один комментарий
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 1,084
