Toshiba Satellite L855-S5119 Random Access Memory Replacement
Введение
Перейти к шагу 1This guide will inform readers on how to replace random access memory because of bad random access memory or the need for more.
Выберете то, что вам нужно
Инструменты
Push the latch on the right to the right to unlock the battery latch locking mechanism.
Push the battery latch on the left to the left to unlock the battery.
With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
The battery will come free.
Turn the laptop over to place it top down.
Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
Lift the back plate off the laptop, exposing the RAM and Hard Disk.
Pull back the two retention clips holding the RAM in place allowing it to pop up.
Remove the RAM by pulling it from the SO-DIMM slot.
2 человек успешно провели ремонт по этому руководству.
