Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Toshiba Satellite M35X-S114 RAM Replacement
Christian Mayorga
Christian Mayorga и 3 другие участники
Последнее обновление January 6, 2015
5 - 10 минут
Средне
Accessing the RAM of the laptop involves removing a screw in order to open an access hatch on the bottom of the laptop. Once opened, the RAM sticks can be unplugged from their slots once released from the metal prongs holding them in place.
Larger capacity RAM sticks can be purchased from most online computer hardware retailers, though you may need to find specific RAM sticks that are compatible with the laptops model. RAM sticks used in laptops are made smaller than typical RAM sticks in order to fit within the laptop's compact size.
Выберете то, что вам нужно
Инструменты
  • Phillips #00 Screwdriver
  1. Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: шаг 1, изображение 1 из 2 Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: шаг 1, изображение 2 из 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: шаг 2, изображение 1 из 2 Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: шаг 2, изображение 2 из 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: шаг 3, изображение 1 из 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: шаг 3, изображение 2 из 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: шаг 4, изображение 1 из 3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: шаг 4, изображение 2 из 3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: шаг 4, изображение 3 из 3
    • Locate the RAM cover around the middle left-hand side of the device.
    • Locate the screw on the RAM cover.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Carefully remove the RAM access hatch.
  5. Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: шаг 5, изображение 1 из 2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: шаг 5, изображение 2 из 2
    • Locate the four silver clips holding the RAM sticks.
    • There is a total of two RAM chips and four silver clips. Two silver clips hold one RAM stick. Remove one RAM stick at a time.
    • Use your fingers from separate hands to pull back the two silver clips away from the sides of the RAM stick.
    • Repeat this step for the other RAM stick.
  6. Toshiba Satellite M35X-S114 RAM Replacement: шаг 6, изображение 1 из 1
    • Gently pull the RAM stick out from its slot.
Заключение
Christian Mayorga
Участник с: 09/09/14
219 Репутация
Автор 2 руководств
Команду
CSU Fullerton, Team 2-4, Bruce Fall 2014 Участник CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 459
