Toshiba Satellite P50W-C RAM Replacement
Введение
Перейти к шагу 1This guide will show you how to replace the RAM. You may need to replace the RAM if your laptop freezes often.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
Push outwards on the metal tabs located on both sides of the RAM to release the RAM. You can use the spudger tool if you have any issues.
Еще один человек закончил это руководство.
