Toshiba Satellite P75-A7100 Fan Replacement
Введение
Перейти к шагу 1Through this guide you will learn to replace the fan inside of your laptop. Make sure you have the proper tools in order to complete the repair. This kind of repair is usually done to fix the problem of your laptop overheating.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove the screw from the back cover.
Remove the back cover from the device.
Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
Remove the back cover from your device.
Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
Remove the Wi-Fi adapter from the device.
Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
Unplug the connector connecting the fan to the motherboard.
Remove the fan from the device.
2 человек успешно провели ремонт по этому руководству.
