Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
Введение
Перейти к шагу 1The motherboard of your device acts as a meeting point for crucial components, such as the CPU and input and output devices. To replace a damaged or defective motherboard, you will remove all connected peripherals, replace the motherboard, and reconnect all peripherals.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
Using the plastic opening tool, remove the two rubber feet closest to the hinge.
Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
Lift the USB controller from the motherboard.
Detach the USB controller from the motherboard.
2 человек успешно провели ремонт по этому руководству.
