Toshiba TECRA R940 RAM Replacement
Введение
Перейти к шагу 1This guide would be useful for replacing broken RAM or upgrading the working RAM to make your Toshiba TECRA R940 run better.
This laptop has a comparatively easy procedure to replace RAM.
Выберете то, что вам нужно
Инструменты
Unscrew the screw attached to the small back panel, and set the back panel aside.
Pull the metal brackets away from the RAM card to unlock it from the slot, then pull the RAM card out.
Repeat the previous step of pulling the RAM card out for the second card, but using the lower brackets.
Еще один человек закончил это руководство.
