Whip Stitch on a Patch
Выберете то, что вам нужно
    1. Whip Stitch on a Patch, Intro to the whip stitch: шаг 1, изображение 1 из 3 Whip Stitch on a Patch, Intro to the whip stitch: шаг 1, изображение 2 из 3 Whip Stitch on a Patch, Intro to the whip stitch: шаг 1, изображение 3 из 3
      • Structure - The whip stitch is a simple looping stitch that creates a spiral of thread.
      • Repair Use - This stretch stitch is highly versatile and can be used to seal a tear, bind a raw fabric edge, or attach a patch.
      • When placed close together, whip stitches can also reinforce an opening to create a buttonhole or a decorative eyelet.
      Спросите у FixBot
      Добавить комментарий
    2. Whip Stitch on a Patch, Assess the damage: шаг 2, изображение 1 из 3 Whip Stitch on a Patch, Assess the damage: шаг 2, изображение 2 из 3 Whip Stitch on a Patch, Assess the damage: шаг 2, изображение 3 из 3
      • Locate and assess the damage.
      • If possible, stitch the tear closed. This will seal the tear on the inside of the patch so it doesn't grow bigger or get caught while the garment is being worn. See Whip Stitch on a Tear.
      • If the tear is too large or oddly shaped to be stitched closed, see the final step in this guide for details on creating an underpatch.
      • If you're repairing Patagonia Quandary Pants with a repair patch included, move on to the next step. Otherwise, see Make a Fabric Patch for guidance and best practices on making a fabric patch.
      Спросите у FixBot
    3. Whip Stitch on a Patch, Removing the fabric patch in Patagonia® Quandary Pants: шаг 3, изображение 1 из 3 Whip Stitch on a Patch, Removing the fabric patch in Patagonia® Quandary Pants: шаг 3, изображение 2 из 3 Whip Stitch on a Patch, Removing the fabric patch in Patagonia® Quandary Pants: шаг 3, изображение 3 из 3
      • Patagonia® Quandary Pants made Spring 2024 or after have a fabric patch included! The patch is located behind the front left pocket bag.
      • Cut the patch out of the pants along the marked cut line.
      • Take care not to cut the pocket bag!
      • Fold over the raw edge and press with an iron.
      • This tutorial will continue using this patch but any patch can be substituted with the same technique.
      Спросите у FixBot
      • Cut a length of thread approximately 24 inches (~61 cm) long.
      • Thread the needle and adjust the thread so there are equal lengths of thread on each side of the needle.
      • Tie an overhand knot with both ends to create a doubled length of thread.
      • The pictured repair uses contrast color thread for visibility, but matching thread will make this repair more invisible.
      • See Needles and Thread for more details.
      Спросите у FixBot
    4. Whip Stitch on a Patch, Pin on the patch: шаг 5, изображение 1 из 3 Whip Stitch on a Patch, Pin on the patch: шаг 5, изображение 2 из 3 Whip Stitch on a Patch, Pin on the patch: шаг 5, изображение 3 из 3
      • Position the fabric patch over the hole and pin it in place, ensuring the hole is centered.
      • Be careful to only pin through one side of the garment, especially if repairing a leg or arm.
      • Place the pins perpendicular to the patch edges, with the pin heads facing outward for easy removal while sewing on the patch.
      Спросите у FixBot
    5. Whip Stitch on a Patch, Start the stitch: шаг 6, изображение 1 из 3 Whip Stitch on a Patch, Start the stitch: шаг 6, изображение 2 из 3 Whip Stitch on a Patch, Start the stitch: шаг 6, изображение 3 из 3
      • Insert the needle into the back of the patch, about 1/4 inch (~6 mm) in from the edge. Pull through so the thread knot is flush against the back of the patch.
      • Starting behind the patch will trap the starting knot between the patch and the garment, and reduce the number of knots the wearer will be able to see or feel.
      • Pierce the needle down at the edge of the patch, into the garment fabric adjacent to the first stitch.
      • Bring the back needle up approximately 1/4 inch (~6 mm) in from the edge of the patch and 1/4 inch (~6 mm) away from the first stitch. Pull the stitch tight.
      • Make sure that this stitch grabs all layers.
      • This technique creates a spiral of thread that adheres the edge of the patch to the garment.
      Спросите у FixBot
    6. Whip Stitch on a Patch, Continue the stitch: шаг 7, изображение 1 из 2 Whip Stitch on a Patch, Continue the stitch: шаг 7, изображение 2 из 2
      • Continue the whip stitch technique around all four edges of the patch, taking care to maintain consistent stitch lengths.
      Спросите у FixBot
    7. Whip Stitch on a Patch, Start a new length of thread: шаг 8, изображение 1 из 3 Whip Stitch on a Patch, Start a new length of thread: шаг 8, изображение 2 из 3 Whip Stitch on a Patch, Start a new length of thread: шаг 8, изображение 3 из 3
      • A single length of thread will likely not be enough to attach the entire patch.
      • When there's approximately 3 to 4 inches (76 to 102 mm) of thread left, pull the needle through to the interior of the garment.
      • Make a secure knot on the backside of the fabric using one of the techniques from Knot Thread to the Fabric (2 Ways) and trim the extra thread.
      • Rethread the needle, knot both ends of the thread, and restart by coming up from behind the patch just as described in Step 6.
      Спросите у FixBot
    8. Whip Stitch on a Patch, Finish the whip stitch: шаг 9, изображение 1 из 3 Whip Stitch on a Patch, Finish the whip stitch: шаг 9, изображение 2 из 3 Whip Stitch on a Patch, Finish the whip stitch: шаг 9, изображение 3 из 3
      • Once the needle is approximately 1/4 inch (~6 mm) from where the stitches began, pierce through to the backside of the garment.
      • Remember to leave 3 to 4 inches (76 to 102 mm) of thread length to have enough to knot off the seam.
      Спросите у FixBot
    9. Whip Stitch on a Patch, Quality check: шаг 10, изображение 1 из 1
      • Check to make sure the patch is securely fastened and all loose thread ends are clipped.
      Спросите у FixBot
    10. Whip Stitch on a Patch, Troubleshooting: шаг 11, изображение 1 из 1
      • UNDERPATCH: If the tear is too large to be stitched closed and there's concern the exposed tear will get caught while the garment is being worn, create an underpatch first. An underpatch is a smaller patch that's sewn over the hole on the backside before the main patch is sewn on the front.
      • The front patch should be large enough to cover the stitching from the underpatch.
      Спросите у FixBot
Финишная прямая
Sabrina K
Участник с: 12/18/24
806 Репутация
Автор 3 руководств
Команда
Patagonia Участник Patagonia
Community
9 членов
Автор 155 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 47
За последние 30 дней: 168
За всё время: 1,236
