iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement
Введение
Перейти к шагу 1Remove your display panel to gain access to the hard drive, optical drive, and power supply.
Выберете то, что вам нужно
Инструменты
Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
Remove the two 5.3 mm T6 Torx screws securing the display data cable to the logic board.
Disconnect the display data cable connector from its socket on the logic board by pulling the attached plastic tab towards you and away from the iMac.
Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
Lift the right side of the display panel a few inches up from the iMac.
With the LCD lifted, disconnect the LCD cable by pulling down.
Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
4 человек успешно провели ремонт по этому руководству.
