iPhone 12 mini Screen Replacement
Выберете то, что вам нужно
  1. iPhone 12 mini Screen Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 12 mini Screen Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    is it oem apple battery, because at some photo shows(Ifixit) and another shows (apple) ... wait your answer?
    karim - Ответить
    BEWARE! This screen isn’t the same as older iPhone models’ screens. The iPhone mini 12-screen comes with a thin plastic frame around the screen on its back. Thus, make sure you don’t insert the pick in between the screen and its plastic frame, as you’ll seperate the screen and leave the plastic frame still sitting in the phone’s metal housing (this cost me 100 dollars…). Carefully heat the sides of the metal housing and do not heat directly on the glass, as doing so will potentially loosen the glue from the plastic frame stuck to the screen. My suggestion is that you watch a video of this repair as this step-by-step-guide is undercooked.
    Dan - Ответить
    This is an excellent comment. Following this step-by-step guide to the letter will break your screen; it's by far the worst iFixit guide I've seen to date.
    Dormouse -
    Ive finished mine and Soooo absolutely dont do this yourself🙌🏽 unless your a mechanic because first of all they didnt send me all of the right tools🤗 and secondly the battery they gave me has an overly large component so it wont fit into my phone. And the absolute HASSEL i had to go through to even just get the package was insane it was a whole month of struggling just for the stuff to not even be right, in conclusion will NEVER order from here again..🤗
    Chanell - Ответить
  2. iPhone 12 mini Screen Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 12 mini Screen Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 12 mini Screen Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Ответить
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Ответить
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Ответить
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Ответить
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Ответить
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Ответить
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Ответить
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Ответить
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Ответить
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Ответить
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Ответить
  3. iPhone 12 mini Screen Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 12 mini Screen Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 12 mini Screen Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 12 mini Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 12 mini Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 12 mini Screen Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 12 mini Screen Replacement: шаг 5, изображение 1 из 3 iPhone 12 mini Screen Replacement: шаг 5, изображение 2 из 3 iPhone 12 mini Screen Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 12 mini Screen Replacement: шаг 6, изображение 1 из 3 iPhone 12 mini Screen Replacement: шаг 6, изображение 2 из 3 iPhone 12 mini Screen Replacement: шаг 6, изображение 3 из 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • Make sure the opening pick is placed properly between the plastic bezel and the frame to avoid damaging your screen.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 12 mini Screen Replacement, Heat the bottom edge of the phone: шаг 7, изображение 1 из 1
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • Heating the bottom edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
    you need to clarify that you're heating the metal frame, not the glass. I gently heated the glass front with a heat gun and proceeded to pull the display apart, destroying it. :-(
    Jim Harger - Ответить
    Don't heat up the display for too long or else you could destroy the display like I did. Now I have a phone with a giant white stripe. So don't be a fool like me. 1 to 2 minutes is enough!
    K T - Ответить
  8. iPhone 12 mini Screen Replacement, Apply a suction handle: шаг 8, изображение 1 из 2 iPhone 12 mini Screen Replacement, Apply a suction handle: шаг 8, изображение 2 из 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    I would recommend starting with a bottom corner, not the bottom middle. If the adhesive isn't softened enough, you will pull the middle out but the sides will still be stuck on, causing extreme flex to the panel and damage to the panel down the middle (white bars down the middle in a worst case). I did this to my phone.
    Drew Kosir - Ответить
  9. iPhone 12 mini Screen Replacement, Lift the screen slightly: шаг 9, изображение 1 из 3 iPhone 12 mini Screen Replacement, Lift the screen slightly: шаг 9, изображение 2 из 3 iPhone 12 mini Screen Replacement, Lift the screen slightly: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the metal frame.
    • A plastic bezel is secured to the underside of the display, and needs to lift up with the display. Inserting a pick between the bezel and the display will damage the panel.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • Make sure the opening pick is placed under the plastic bezel (against the frame) to avoid damaging your screen.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    I ended up separating my screen rather than getting under the scren casing.. BE CAREFUL TO MAKE SURE YOU ARE UNDER THE PLASTIC PART - otherwise you just ruin your screen... No mention of this precaution here and as a result, my phone is more broken than when I started
    Tyler Ludwig - Ответить
    Hi, I don’t get it. Should the plastic part stay with the display or with the phone?
    Paul - Ответить
    The plastic frame should stay with the display.
    Carsten Frauenheim -
    Be sure you see two layers: glas and plastic (Step 6, Clamp, last picture). You have to go underneath the plastic frame otherwise you are tearing your displayglas off the frame and destroy your OLED!
    Johnny RS - Ответить
    Broke the screen. Too bad. I've done maybe 5 battery replacements before. But this one is very very tight. Got a new phone. :P
    Gilles van Leeuwen - Ответить
    Same thing, I broke my screen too. I think the warning should be in all caps and show more clearly where is the right place to put the pick and where is not — without the need to click on the link.
    Judging by amount of people who reported it here (and should also account for those who didn't bother to report), I'd say that there is a problem with instructions.
    It is honestly not so hard if you know what does mistake looks like and that it is possible to separate the screen so easily from the frame. I repaired more than a dozen phones — screens and batteries — and this is the first time I made such a mistake that costs 100+euros.
    Axel Mort - Ответить
  10. iPhone 12 mini Screen Replacement, Heat the right edge: шаг 10, изображение 1 из 2 iPhone 12 mini Screen Replacement, Heat the right edge: шаг 10, изображение 2 из 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
    The pictures show the left side. I know that the left side is the correct one to heat, but for others it might be confusing. 😊
    Donát Viosz - Ответить
    @dviosz You mean the right edge! The picture shows the left edge but the right edge is the correct one to heat. As described in the text next to it. Opening the phone from the left will damage it!
    catchMyException - Ответить
    Yeah, sorry, you are right! (tried to make something less confusing and created more confusion by accident… 😃 )
    Donát Viosz -
    THIS ONE HERE (lolz)
    weebeast -
  11. iPhone 12 mini Screen Replacement, Separate the screen adhesive: шаг 11, изображение 1 из 3 iPhone 12 mini Screen Replacement, Separate the screen adhesive: шаг 11, изображение 2 из 3 iPhone 12 mini Screen Replacement, Separate the screen adhesive: шаг 11, изображение 3 из 3
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Be very careful your tool does NOT go in between the screen and the screen frame but rather in between the screen frame and the phone frame. If not you will damage the screen and need a new one. This has happened to MANY people. The screen is attached to the screen frame with an adhesive that can also be accidentally pried apart if not done carefully. This is probably more likely if your tool is too thin, if you dont heat enough, or dont suction and pull enough to create a big enough separation between the screen frame and the phone frame.
    Ezra Gilbert - Ответить
    Yes, this happens to me, too. It took a long time until I could remove the screen using a heat gun with a heat gun set to 120°C (after trying first with 90° and 100°). Now the right side of the display shows white stripes and the touch doesn't react. -> New display necessary...
    Bernd Löhr - Ответить
  12. iPhone 12 mini Screen Replacement, Heat the top edge: шаг 12, изображение 1 из 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 mini Screen Replacement: шаг 13, изображение 1 из 3 iPhone 12 mini Screen Replacement: шаг 13, изображение 2 из 3 iPhone 12 mini Screen Replacement: шаг 13, изображение 3 из 3
    • The top edge of the display is secured with both glue and clips.
    • Insert your pick underneath the top-right corner of the display panel.
    • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
    • Slide the pick along the top edge and cut any remaining adhesive securing the display.
  14. iPhone 12 mini Screen Replacement, Heat the left edge: шаг 14, изображение 1 из 2 iPhone 12 mini Screen Replacement, Heat the left edge: шаг 14, изображение 2 из 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 mini Screen Replacement, Screen information: шаг 15, изображение 1 из 1
    • There are two delicate cables along the left edge of your iPhone, one near the top and one slightly below the middle. Don't insert your pick here, as you may damage the cable.
    There are two cables, one near the top, another lower than the middle on the left side. Further steps show where the second one is, but this picture doesn't show it...
    mesanos - Ответить
    Welches Ersatzteil benötige ich, wenn die obere Verbindung gerissen ist?
    Claudia T. - Ответить
    If the inside of your phone looks different than these photos (like me) then you may have only removed the top layer of the screen assembly. The bottom layer should pry up easily enough with tweezers.
    macro - Ответить
    I accidentally tore the cables off. What can I do?
    Alma Hernandez - Ответить
    The display flexy is in the middle of the left side, please update the picture showing the flexy connected and highlight in red, so other users don't damage it as I did :(
    Juan David Zuluaga - Ответить
    Updated -- thank you! Does this look better?
    Spencer Pennington -
  16. iPhone 12 mini Screen Replacement, Separate the left adhesive: шаг 16, изображение 1 из 2 iPhone 12 mini Screen Replacement, Separate the left adhesive: шаг 16, изображение 2 из 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
    Don't go from just one corner (like on the right side). I've done that (forgot this step) and broke my screen.
  17. iPhone 12 mini Screen Replacement, Open the iPhone: шаг 17, изображение 1 из 3 iPhone 12 mini Screen Replacement, Open the iPhone: шаг 17, изображение 2 из 3 iPhone 12 mini Screen Replacement, Open the iPhone: шаг 17, изображение 3 из 3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 12 mini Screen Replacement, Unscrew the battery and display connector cover: шаг 18, изображение 1 из 2 iPhone 12 mini Screen Replacement, Unscrew the battery and display connector cover: шаг 18, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    hallo, ich sehe in Schritt 17 nur EINE markierte Schraube... (?)
    marrei1964 - Ответить
    So i got the kit how do you expect with the tools you gave me i should get that tiny screw out?? Its requires a 3 way screw i have a 4 and 2 5 ways 🤔
    Chanell - Ответить
    This Shield is garbage and once it's taken out it's next to impossible to get back in. I'm not even going to put the shield back in I'm just going to put kapton tape over it and call it good.
    Zach Benson - Ответить
  19. iPhone 12 mini Screen Replacement, Remove the battery and display connector cover: шаг 19, изображение 1 из 2 iPhone 12 mini Screen Replacement, Remove the battery and display connector cover: шаг 19, изображение 2 из 2
    • Use a pair of tweezers to remove the battery & display connector bracket.
    • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
  20. iPhone 12 mini Screen Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 iPhone 12 mini Screen Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 12 mini Screen Replacement, Disconnect the OLED display cable: шаг 21, изображение 1 из 2 iPhone 12 mini Screen Replacement, Disconnect the OLED display cable: шаг 21, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 12 mini Screen Replacement, Unscrew the front sensor assembly cover: шаг 22, изображение 1 из 2 iPhone 12 mini Screen Replacement, Unscrew the front sensor assembly cover: шаг 22, изображение 2 из 2
    • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
    There is an error here. There are different screws. 2 large and 3 small.
    zeidin09 - Ответить
    what 3 are the small ones? I don't know anymore
    Thomas Klep - Ответить
    in case anyone else reads this, the 3 small ones screw directly onto the board. the two longer ones screw into standoffs (the two top screws, based on the picture above)
    Skyejobs -
  23. iPhone 12 mini Screen Replacement: шаг 23, изображение 1 из 2 iPhone 12 mini Screen Replacement: шаг 23, изображение 2 из 2
    • Use a pair of tweezers to remove the front sensor assembly bracket.
  24. iPhone 12 mini Screen Replacement, Disconnect the front sensors: шаг 24, изображение 1 из 2 iPhone 12 mini Screen Replacement, Disconnect the front sensors: шаг 24, изображение 2 из 2
    • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
  25. iPhone 12 mini Screen Replacement, Remove the display assembly: шаг 25, изображение 1 из 1
  26. iPhone 12 mini Screen Replacement, Unscrew the front sensor and speaker assembly: шаг 26, изображение 1 из 2 iPhone 12 mini Screen Replacement, Unscrew the front sensor and speaker assembly: шаг 26, изображение 2 из 2
    • Remove the 1.1 mm-long tri-point Y000 screw.
    • Remove the 1.8 mm-long tri-point Y000 screw.
    • Remove the two 1.6 mm-long Phillips #00 screws.
    • Don't try to remove the front sensor and speaker assembly yet. It's still glued to the rear side of the display panel.
  27. iPhone 12 mini Screen Replacement: шаг 27, изображение 1 из 2 iPhone 12 mini Screen Replacement: шаг 27, изображение 2 из 2
    • Slide the flat end of a spudger underneath the top right corner of the earpiece speaker and fold it to the back.
  28. iPhone 12 mini Screen Replacement, Heat up the top edge of the display: шаг 28, изображение 1 из 1
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  29. iPhone 12 mini Screen Replacement, Pry up the proximity sensor: шаг 29, изображение 1 из 2 iPhone 12 mini Screen Replacement, Pry up the proximity sensor: шаг 29, изображение 2 из 2
    • Use the pointed end of a spudger to carefully pry the proximity sensor out of its recess.
  30. iPhone 12 mini Screen Replacement: шаг 30, изображение 1 из 2 iPhone 12 mini Screen Replacement: шаг 30, изображение 2 из 2
    • Slide a spudger underneath the wide sensor assembly flex cable to separate it from the screen.
    • Avoid tensioning any of the sensor flex cables during this procedure.
  31. iPhone 12 mini Screen Replacement, Pry up the flood illuminator: шаг 31, изображение 1 из 2 iPhone 12 mini Screen Replacement, Pry up the flood illuminator: шаг 31, изображение 2 из 2
    • Use a spudger or a pair of tweezers to pry the flood illuminator out of its recess.
  32. iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: шаг 32, изображение 1 из 3 iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: шаг 32, изображение 2 из 3 iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: шаг 32, изображение 3 из 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the sensors and the microphone. Avoid obstructing them with any adhesive.
    • Flood illuminiator
    • Proximity sensor
    • Microphone
    Probably the Proximity sensor is in the wrong position.
    What is surrounded by the orange frame is not the Proximity sensor, but the Ambient light sensor.
    Zume - Ответить
Заключение
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Check out our iPhone 12 mini Answers community for troubleshooting help.
46 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
230 763 Репутация
Автор 682 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 636 руководств
12Комментарии к руководству
so does apple have to pair it?
Roman - Ответить
The only way to pair the new sceen to the phone to retain Tue Tone is to buy a dedicated board that copy the data from the original screen to the new.
Daniele Carminati -
This guide was impeccable! The hardest part is definitely getting the screen glue off. Ended up separating the frame of the screen from the display itself. All worked out in the end though!
Thomas Hubbell - Ответить
same! I was wondering why the inside of my phone looked different than the pictures before realizing the screen assembly has two layers and I accidentally removed only the top one instead of both.
Likewise, worked out for me anyhow.
macro -
The same thing happened to me. So a simple battery replacement turned into a display replacement :D
Roman Fialka -
Should the phone turn ON and screen work with out speaker/sensor module?
Oleksii Nazaruk - Ответить
I wish they would include the way to put the water resistant gasket on, not all of us know what to do.
PAUL WHEELER - Ответить
one of the steps above (in reverse order) links to a different guide for replacing the water resistant gasket
macro -
So I have an iPhone 12, just the basic model. When I removed the screen assemble, the camera/speaker/mic setup was not attached to the old screen. I thought maybe I broke a cable, but there doesn't appear to be any screw points for the camera assemble on the old screen. Also, the upper cable when you hinge the old screen open isn't attached to the screen. Finally, there do not appear to be any clips on the old screen, and the replacement screen does have clips, but they do not appear to go into anything in the iPhone 12 body. The replacement screen also has screw points for the camera assemble to attach to. Do I not have an iPhone 12?
stagebuilder - Ответить
This is the iPhone 12 MINI guide iPhone 12 Screen Replacement this is the iphone 12 guide
Kidopher Chris -
Do not open it like a book at STEP 16.
There is a small metal piece on the left side of the screen that extends deep into the iPhone’s frame. If you open it like a book, you risk bending it and damaging your screen.
Instead, carefully lift the entire screen by just 1 or 2 millimeters before opening it with great caution.
AntoineH - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 110
За последние 7 дней: 686
За последние 30 дней: 3,297
За всё время: 123,734
