iPhone 15 Pro Max Taptic Engine Replacement
Выберете то, что вам нужно
    1. iPhone 15 Pro Max Taptic Engine Replacement, Prepare your phone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Prepare your phone for disassembly: шаг 1, изображение 2 из 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Спросите у FixBot
      Добавить комментарий
    2. iPhone 15 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 1
      • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Спросите у FixBot
    2. iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Спросите у FixBot
    3. iPhone 15 Pro Max Taptic Engine Replacement, Screen information: шаг 7, изображение 1 из 1
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      Спросите у FixBot
    4. iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Спросите у FixBot
    5. iPhone 15 Pro Max Taptic Engine Replacement, Heat the right edge: шаг 9, изображение 1 из 1
      • Heat the right edge of the screen until it's hot to the touch.
      Спросите у FixBot
    6. iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: шаг 10, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: шаг 10, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Position the opening pick: шаг 10, изображение 3 из 3
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      Спросите у FixBot
    7. iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: шаг 11, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: шаг 11, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Release the right clip: шаг 11, изображение 3 из 3
      • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
      • Insert a second opening pick to the right of the first pick.
      Спросите у FixBot
    8. iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the right edge adhesive: шаг 12, изображение 3 из 3
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      Спросите у FixBot
    9. iPhone 15 Pro Max Taptic Engine Replacement, Heat the top edge: шаг 13, изображение 1 из 1
      • Heat the top edge of the screen until it's hot to the touch.
      Спросите у FixBot
    10. iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      Спросите у FixBot
    11. iPhone 15 Pro Max Taptic Engine Replacement, Heat the left edge: шаг 15, изображение 1 из 1
      • Heat the left edge of the screen until it's hot to the touch.
      Спросите у FixBot
    12. iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: шаг 16, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: шаг 16, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the left edge adhesive: шаг 16, изображение 3 из 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: шаг 17, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: шаг 17, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Swing open the screen: шаг 17, изображение 3 из 3
      • Gently swing open the screen to the left of the phone.
      • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the screen against a box or similar object so it doesn't strain the cables.
      Спросите у FixBot
    2. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the logic board cover: шаг 18, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the logic board cover: шаг 18, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      FixMat
      $36.95
      • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
      • One 2.1 mm‑long screw
      • Five 1.5 mm‑long screws
      Спросите у FixBot
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: шаг 19, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: шаг 19, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the logic board cover: шаг 19, изображение 3 из 3
      • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
      • Remove the cover.
      Спросите у FixBot
    4. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 20, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 20, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the battery: шаг 20, изображение 3 из 3
      • Use the tip of an opening pick to pry up and disconnect the battery press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the ambient light sensor: шаг 21, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the ambient light sensor: шаг 21, изображение 2 из 2
      • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
      Спросите у FixBot
    2. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the screen: шаг 22, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the screen: шаг 22, изображение 2 из 2
      • Disconnect the screen press connector.
      Спросите у FixBot
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the screen: шаг 23, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Remove the screen: шаг 23, изображение 2 из 2
      • Remove the screen.
      • During reassembly, stop here and use this guide to install new screen adhesive.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the loudspeaker: шаг 24, изображение 1 из 1
      • Use your Phillips #000 driver to remove the four screws securing the loudspeaker:
      • Three 2.1 mm screws
      • One 2.9 mm screw
      Спросите у FixBot
    2. iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: шаг 25, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: шаг 25, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Separate the tape: шаг 25, изображение 3 из 3
      • A piece of tape connects the top edges of the Taptic Engine and loudspeaker.
      • Insert an opening pick under the tape in the small gap between the Taptic Engine and the loudspeaker.
      • Slide the pick toward the left edge of the phone to separate the tape from the Taptic Engine.
      Спросите у FixBot
    3. iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: шаг 26, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: шаг 26, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the loudspeaker: шаг 26, изображение 3 из 3
      • Insert the flat end of a spudger between the right edge of the loudspeaker and the frame.
      • Pry up until you can grab the loudspeaker with your fingers.
      • Remove the loudspeaker.
      Спросите у FixBot
    1. iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: шаг 27, изображение 1 из 2 iPhone 15 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: шаг 27, изображение 2 из 2
      • Use the tip of your spudger to pry up and disconnect the Taptic Engine press connector.
      Спросите у FixBot
    2. iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: шаг 28, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: шаг 28, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the grounding clip: шаг 28, изображение 3 из 3
      • Remove the two screws securing the grounding clip:
      • One 1.2 mm Phillips #000 screw
      • One 1.9 mm tri-point Y000 screw
      • Use tweezers to remove the grounding clip.
      Спросите у FixBot
    3. iPhone 15 Pro Max Taptic Engine Replacement, Unfasten the Taptic Engine: шаг 29, изображение 1 из 1
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the two screws securing the Taptic Engine:
      • One 2.9 mm Phillips #000 screw
      • One 3.8 mm standoff screw
      • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
      Спросите у FixBot
    4. iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 30, изображение 1 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 30, изображение 2 из 3 iPhone 15 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: шаг 30, изображение 3 из 3
      • Insert the flat end of a spudger between the left edge of the Taptic Engine and the frame.
      • Pry up until you can grab the Taptic Engine with your fingers.
      • Remove the Taptic Engine.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Clay Eickemeyer
Участник с: 09/19/22
105 984 Репутация
Автор 472 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 36 559 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 85
За последние 30 дней: 331
За всё время: 8,029
