iPhone 6 Home Button Replacement
Выберете то, что вам нужно
Видеообзор
  1. iPhone 6 Home Button Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 6 Home Button Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6 Home Button Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6 Home Button Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  3. iPhone 6 Home Button Replacement: шаг 3, изображение 1 из 3 iPhone 6 Home Button Replacement: шаг 3, изображение 2 из 3 iPhone 6 Home Button Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  4. iPhone 6 Home Button Replacement, Manual Opening Procedure: шаг 4, изображение 1 из 1
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Спросите у FixBot
  5. iPhone 6 Home Button Replacement: шаг 5, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    Спросите у FixBot
  6. iPhone 6 Home Button Replacement: шаг 6, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 6, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    Спросите у FixBot
  7. iPhone 6 Home Button Replacement, Opening up the phone: шаг 7, изображение 1 из 3 iPhone 6 Home Button Replacement, Opening up the phone: шаг 7, изображение 2 из 3 iPhone 6 Home Button Replacement, Opening up the phone: шаг 7, изображение 3 из 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
    Спросите у FixBot
  8. iPhone 6 Home Button Replacement: шаг 8, изображение 1 из 3 iPhone 6 Home Button Replacement: шаг 8, изображение 2 из 3 iPhone 6 Home Button Replacement: шаг 8, изображение 3 из 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    Спросите у FixBot
  9. iPhone 6 Home Button Replacement, Removing the battery connector bracket screws: шаг 9, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    Спросите у FixBot
  10. iPhone 6 Home Button Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
    Спросите у FixBot
  11. iPhone 6 Home Button Replacement, Disconnecting the battery connector: шаг 11, изображение 1 из 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
    Спросите у FixBot
  12. iPhone 6 Home Button Replacement, Removing the front panel assembly cable bracket screws: шаг 12, изображение 1 из 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
    Спросите у FixBot
  13. iPhone 6 Home Button Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
    Спросите у FixBot
  14. iPhone 6 Home Button Replacement: шаг 14, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 14, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
    Спросите у FixBot
  15. iPhone 6 Home Button Replacement: шаг 15, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 15, изображение 2 из 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
    Спросите у FixBot
  16. iPhone 6 Home Button Replacement: шаг 16, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 16, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
    Спросите у FixBot
  17. iPhone 6 Home Button Replacement: шаг 17, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 17, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    Спросите у FixBot
  18. iPhone 6 Home Button Replacement, Separating front panel assembly and rear case: шаг 18, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
    Спросите у FixBot
  19. iPhone 6 Home Button Replacement, Home Button: шаг 19, изображение 1 из 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
    Спросите у FixBot
  20. iPhone 6 Home Button Replacement: шаг 20, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 20, изображение 2 из 2
    • Remove the home button bracket from the front panel.
    Спросите у FixBot
  21. iPhone 6 Home Button Replacement: шаг 21, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 21, изображение 2 из 2
    • Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
    Спросите у FixBot
  22. iPhone 6 Home Button Replacement: шаг 22, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 22, изображение 2 из 2
    iOpener
    $24.95
    • The rubber membrane surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
    • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
    Спросите у FixBot
  23. iPhone 6 Home Button Replacement: шаг 23, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 23, изображение 2 из 2
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
    Спросите у FixBot
  24. iPhone 6 Home Button Replacement: шаг 24, изображение 1 из 2 iPhone 6 Home Button Replacement: шаг 24, изображение 2 из 2
    iOpener
    $14.95
    • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
    Спросите у FixBot
  25. iPhone 6 Home Button Replacement: шаг 25, изображение 1 из 1
    • Once all the adhesive has been separated, remove the home button from the front panel.
    • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
    • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    Спросите у FixBot
  26. iPhone 6 Home Button Replacement, Home Button: шаг 26, изображение 1 из 3 iPhone 6 Home Button Replacement, Home Button: шаг 26, изображение 2 из 3 iPhone 6 Home Button Replacement, Home Button: шаг 26, изображение 3 из 3
    • Depending on your replacement part, you may need to remove the rubber gasket around your home button.
    • Use a set of tweezers to carefully pull the gasket up from the home button.
    • Be careful not to snag the gasket on the home button cable.
    Спросите у FixBot
Заключение
394 человек успешно провели ремонт по этому руководству.
Sam Goldheart
Участник с: 10/18/12
477 664 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 27 554 руководств
69 Комментарии к руководству
is this the original home button?
costasefth23 - Ответить Поделиться
My home button doesnt working while my touch id is working fine. I ask this repair shop he said , if u get this phone repaired, ur touch id wont working. How can i settle this down with free risk
sufian ahmad - Ответить Поделиться
جهاز أيفون 6 البصمة تخرب بسرعة
Abdulaziz Alhammad - Ответить Поделиться
You can't update your phone when you don't have the original home button, any solutions?
brampeeters122 - Ответить Поделиться
I work at an Apple repair centre in based in the UK and we have recently encountered MAJOR issues with replacement home buttons. It turns out that home buttons are linked too the logic board on each handset due to the method in which Apple stores you biometric data. Due to this, to the greatest extent of our knowledge, any update (through setting on the phone, updating on the phone, updating through iTunes or resting on iTunes) will cause an ERROR 53 to occur. As of yet we have not be able to rescue a handset from this state. If any body has any further knowledge it would be massively appreciated, as a community we need to get to the bottom of this before anybody had any major disasters.
jakebennettyoung - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 65
За последние 30 дней: 290
За всё время: 627,778
