iPhone 6 Rear Case Replacement
Выберете то, что вам нужно
  1. iPhone 6 Rear Case Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 6 Rear Case Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6 Rear Case Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6 Rear Case Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  3. iPhone 6 Rear Case Replacement: шаг 3, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 3, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  4. iPhone 6 Rear Case Replacement, Manual Opening Procedure: шаг 4, изображение 1 из 1
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Спросите у FixBot
  5. iPhone 6 Rear Case Replacement: шаг 5, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    Спросите у FixBot
  6. iPhone 6 Rear Case Replacement: шаг 6, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 6, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    Спросите у FixBot
  7. iPhone 6 Rear Case Replacement, Opening up the phone: шаг 7, изображение 1 из 3 iPhone 6 Rear Case Replacement, Opening up the phone: шаг 7, изображение 2 из 3 iPhone 6 Rear Case Replacement, Opening up the phone: шаг 7, изображение 3 из 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
    Спросите у FixBot
  8. iPhone 6 Rear Case Replacement: шаг 8, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 8, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 8, изображение 3 из 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    Спросите у FixBot
  9. iPhone 6 Rear Case Replacement, Removing the battery connector bracket screws: шаг 9, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    Спросите у FixBot
  10. iPhone 6 Rear Case Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
    Спросите у FixBot
  11. iPhone 6 Rear Case Replacement, Disconnecting the battery connector: шаг 11, изображение 1 из 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
    Спросите у FixBot
  12. iPhone 6 Rear Case Replacement, Removing the front panel assembly cable bracket screws: шаг 12, изображение 1 из 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
    Спросите у FixBot
  13. iPhone 6 Rear Case Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
    Спросите у FixBot
  14. iPhone 6 Rear Case Replacement: шаг 14, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 14, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
    Спросите у FixBot
  15. iPhone 6 Rear Case Replacement: шаг 15, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 15, изображение 2 из 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
    Спросите у FixBot
  16. iPhone 6 Rear Case Replacement: шаг 16, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 16, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
    Спросите у FixBot
  17. iPhone 6 Rear Case Replacement: шаг 17, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 17, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    Спросите у FixBot
  18. iPhone 6 Rear Case Replacement, Separating front panel assembly and rear case: шаг 18, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
    Спросите у FixBot
  19. iPhone 6 Rear Case Replacement, SIM Card: шаг 19, изображение 1 из 2 iPhone 6 Rear Case Replacement, SIM Card: шаг 19, изображение 2 из 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
    Спросите у FixBot
  20. iPhone 6 Rear Case Replacement: шаг 20, изображение 1 из 1
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Спросите у FixBot
  21. iPhone 6 Rear Case Replacement, Logic Board: шаг 21, изображение 1 из 2 iPhone 6 Rear Case Replacement, Logic Board: шаг 21, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
    Спросите у FixBot
  22. iPhone 6 Rear Case Replacement: шаг 22, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 22, изображение 2 из 2
    • Use the point of a spudger to lift the antenna cable connector up off of its socket on the logic board.
    Спросите у FixBot
  23. iPhone 6 Rear Case Replacement: шаг 23, изображение 1 из 1
    • Remove the following Phillips screws from the upper cable bracket:
    • One 2.9 mm screw
    • One 2.2 mm screw
    Спросите у FixBot
  24. iPhone 6 Rear Case Replacement: шаг 24, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 24, изображение 2 из 2
    • Remove the upper cable bracket from the iPhone.
    Спросите у FixBot
  25. iPhone 6 Rear Case Replacement: шаг 25, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 25, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 25, изображение 3 из 3
    • When disconnecting the following connectors, only pry up on the connector, not the socket on the logic board or you risk permanent damage.
    • Use the flat end of a spudger to lift the power button and flash assembly cable connector up off of its socket.
    • Lift the volume control cable connector up out of its socket on the logic board.
    Спросите у FixBot
  26. iPhone 6 Rear Case Replacement: шаг 26, изображение 1 из 1
    • Remove the following four Phillips screws from the Wi-Fi antenna:
    • One 1.5 mm screw
    • One 1.4 mm screw
    • Two 2.1 mm screws
    Спросите у FixBot
  27. iPhone 6 Rear Case Replacement: шаг 27, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 27, изображение 2 из 2
    • Remove the Wi-Fi antenna from the iPhone.
    • Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
    Спросите у FixBot
  28. iPhone 6 Rear Case Replacement: шаг 28, изображение 1 из 1
    • Remove the two 1.6 mm Phillips screws from the grounding bracket.
    Спросите у FixBot
  29. iPhone 6 Rear Case Replacement: шаг 29, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 29, изображение 2 из 2
    • Remove the grounding bracket from the iPhone.
    Спросите у FixBot
  30. iPhone 6 Rear Case Replacement: шаг 30, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 30, изображение 2 из 2
    • Remove the following Phillips screws securing the angled logic board bracket.
    • One 2.6 mm screw
    • One 1.3 mm screw, located horizontally in the upper sidewall of the iPhone.
    Спросите у FixBot
  31. iPhone 6 Rear Case Replacement: шаг 31, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 31, изображение 2 из 2
    • Remove the angled logic board bracket.
    Спросите у FixBot
  32. iPhone 6 Rear Case Replacement: шаг 32, изображение 1 из 1
    • Remove the single 1.2 mm Phillips screw securing the antenna interconnect cable to the logic board.
    Спросите у FixBot
  33. iPhone 6 Rear Case Replacement: шаг 33, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 33, изображение 2 из 2
    • Use the point of a spudger to fold the antenna interconnect cable up out of the way of the logic board.
    Спросите у FixBot
  34. iPhone 6 Rear Case Replacement: шаг 34, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 34, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 34, изображение 3 из 3
    • Use the flat end of a spudger to lift the camera cable connector straight up out of its socket on the logic board.
    • Be sure to only pry on the connector not the socket itself or you can cause permanent damage to the logic board.
    • Fold the camera cable up out of the way of the logic board.
    Спросите у FixBot
  35. iPhone 6 Rear Case Replacement: шаг 35, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 1.9 mm Phillips screws
    • One 2.3 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Спросите у FixBot
  36. iPhone 6 Rear Case Replacement: шаг 36, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 36, изображение 2 из 2
    • Use the flat end of a spudger to lift the battery connector end of the logic board up slightly, just enough to grab with your fingers.
    • Insert the spudger near the metal shields below the SIM card tray to avoid damaging any chips or sockets.
    Спросите у FixBot
  37. iPhone 6 Rear Case Replacement: шаг 37, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 37, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 37, изображение 3 из 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Спросите у FixBot
  38. iPhone 6 Rear Case Replacement, Power Button Cable Assembly: шаг 38, изображение 1 из 1
    • Peel back the first battery adhesive tab from the bottom right edge of the battery.
    • Use your fingers or blunt tweezers, and be extra careful when working near the battery—puncturing a lithium-ion battery can release dangerous chemicals and cause a fire.
    Спросите у FixBot
  39. iPhone 6 Rear Case Replacement: шаг 39, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 39, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 39, изображение 3 из 3
    • Gently pull the battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Try not to pull against the battery or the lower components, or you may rip the adhesive strip.
    • Continue pulling, allowing the strip to slowly slip out from between the battery and the rear case. When you feel increased resistance from the strip, stop pulling and continue with the next step.
    • If the battery adhesive tabs break off at any point during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then proceed to Step 44.
    Спросите у FixBot
  40. iPhone 6 Rear Case Replacement: шаг 40, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 40, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 40, изображение 3 из 3
    • When you feel increased resistance from the adhesive strip, pull it gently around the lower right corner of the battery.
    • Continue pulling the adhesive tab upward and away from the right edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
    • Don't allow the adhesive strip to snag on the battery connector, or it may tear or break off.
    Спросите у FixBot
  41. iPhone 6 Rear Case Replacement: шаг 41, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 41, изображение 2 из 2
    • Peel back the second battery adhesive tab from the bottom left edge of the battery.
    • Again, gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
    • Continue pulling the adhesive tab until you feel increased resistance, and then stop.
    Спросите у FixBot
  42. iPhone 6 Rear Case Replacement: шаг 42, изображение 1 из 1
    • When you feel increased resistance from the adhesive strip, pull it gently around the lower left corner of the battery.
    • Don't allow the adhesive strip to snag on the corner of the battery, or it may tear or break off.
    • Continue pulling the adhesive tab upward and away from the left edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
    • If you removed both adhesive strips successfully, skip the next two steps and continue on Step 46.
    • If either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
    Спросите у FixBot
  43. iPhone 6 Rear Case Replacement: шаг 43, изображение 1 из 1
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    Спросите у FixBot
  44. iPhone 6 Rear Case Replacement: шаг 44, изображение 1 из 1
    Plastic Cards
    $2.99
    • Insert a plastic card under the logic board edge of the battery.
    • Be careful to keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Press the card in at several points if necessary to break up the adhesive behind the battery.
    Спросите у FixBot
  45. iPhone 6 Rear Case Replacement: шаг 45, изображение 1 из 1
    • After peeling or prying out all adhesive, remove the battery from the iPhone.
    • When reinstalling the battery, refer to this guide to replace your battery's adhesive strips.
    Спросите у FixBot
  46. iPhone 6 Rear Case Replacement: шаг 46, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 46, изображение 2 из 2
    • Remove any tape covering the upper left rear-facing camera screw.
    Спросите у FixBot
  47. iPhone 6 Rear Case Replacement: шаг 47, изображение 1 из 1
    • Remove the following Phillips #00 screws from the rear-facing camera bracket:
    • One 1.5 mm screw
    • One 2.1 mm screw
    Спросите у FixBot
  48. iPhone 6 Rear Case Replacement: шаг 48, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 48, изображение 2 из 2
    • Remove the rear-facing camera bracket.
    Спросите у FixBot
  49. iPhone 6 Rear Case Replacement: шаг 49, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 49, изображение 2 из 2
    • Carefully remove the antenna interconnect cable from the rear case.
    Спросите у FixBot
  50. iPhone 6 Rear Case Replacement: шаг 50, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 50, изображение 2 из 2
    • Remove the rear-facing camera from the iPhone.
    Спросите у FixBot
  51. iPhone 6 Rear Case Replacement: шаг 51, изображение 1 из 1
    • Remove the single 1.2 mm Phillips #00 screw securing the flash bracket.
    Спросите у FixBot
  52. iPhone 6 Rear Case Replacement: шаг 52, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 52, изображение 2 из 2
    • Remove the flash bracket from the rear case.
    Спросите у FixBot
  53. iPhone 6 Rear Case Replacement: шаг 53, изображение 1 из 1
    • Remove the two 2.2 mm Phillips #00 screws from the power button bracket.
    Спросите у FixBot
  54. iPhone 6 Rear Case Replacement: шаг 54, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 54, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 54, изображение 3 из 3
    • Use the point of a spudger to gently push the flash and microphone modules up out of their respective holes in the rear case.
    • If you encounter significant adhesive, use tweezers to peel the components up from the rear case.
    Спросите у FixBot
  55. iPhone 6 Rear Case Replacement: шаг 55, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 55, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 55, изображение 3 из 3
    • Begin to peel the flash/microphone/power button assembly cable up from the rear case starting from the connector end.
    • Continue to peel the cable up, being particularly careful of the narrow component ends of the cable.
    • Remove the flash/microphone/power button assembly cable from the phone.
    Спросите у FixBot
  56. iPhone 6 Rear Case Replacement, Power Button: шаг 56, изображение 1 из 2 iPhone 6 Rear Case Replacement, Power Button: шаг 56, изображение 2 из 2
    • Grip the power button by the metal bar to pull it free from the rear case.
    • The power button is held to the case with an adhesive gasket, pull carefully to prevent ripping the membrane.
    Спросите у FixBot
  57. iPhone 6 Rear Case Replacement, Rear Case: шаг 57, изображение 1 из 1
    • Remove the following Phillips #00 screws from the volume control cable brackets:
    • Two 2.3 mm screws
    • One 1.8 mm screw
    Спросите у FixBot
  58. iPhone 6 Rear Case Replacement: шаг 58, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 58, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 58, изображение 3 из 3
    • Pull the hold switch and volume control button brackets away from the rear case to allow access to the button covers.
    Спросите у FixBot
  59. iPhone 6 Rear Case Replacement: шаг 59, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 59, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 59, изображение 3 из 3
    • Begin to peel the volume control button cable up from the rear case starting from the connector end.
    • Be gentle when peeling the thin portions of the cable up from the case.
    • Remove the volume control button cable from the rear case.
    Спросите у FixBot
  60. iPhone 6 Rear Case Replacement: шаг 60, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 60, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 60, изображение 3 из 3
    • Pull the volume control buttons by the metal bar to remove them from the rear case.
    • The buttons are held to the case with an adhesive gasket, pull carefully to prevent ripping the membrane.
    Спросите у FixBot
  61. iPhone 6 Rear Case Replacement: шаг 61, изображение 1 из 1
    • Remove the following four Phillips #00 screws securing the speaker:
    • Two 2.9 mm screws
    • Two 2.3 mm screws
    Спросите у FixBot
  62. iPhone 6 Rear Case Replacement: шаг 62, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 62, изображение 2 из 2
    • Use the point of a spudger to push the antenna interconnect cable clip off of the speaker housing.
    Спросите у FixBot
  63. iPhone 6 Rear Case Replacement: шаг 63, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 63, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 63, изображение 3 из 3
    • Pull the speaker up and out of the rear case.
    Спросите у FixBot
  64. iPhone 6 Rear Case Replacement: шаг 64, изображение 1 из 1
    • Remove the two 1.6 mm Phillips #00 screws securing the vibrator to the rear case.
    Спросите у FixBot
  65. iPhone 6 Rear Case Replacement: шаг 65, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 65, изображение 2 из 2
    • Remove the vibrator from the iPhone.
    Спросите у FixBot
  66. iPhone 6 Rear Case Replacement: шаг 66, изображение 1 из 1
    • Remove the two 3.1 mm Phillips #00 screws securing the Lightning port retaining bracket.
    Спросите у FixBot
  67. iPhone 6 Rear Case Replacement: шаг 67, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 67, изображение 2 из 2
    • Remove the Lightning port retaining bracket.
    Спросите у FixBot
  68. iPhone 6 Rear Case Replacement: шаг 68, изображение 1 из 1
    • Remove the single 3.6 mm Phillips #00 shoulder screw from the microphone brace.
    Спросите у FixBot
  69. iPhone 6 Rear Case Replacement: шаг 69, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 69, изображение 2 из 2
    • Remove the microphone brace from the iPhone.
    Спросите у FixBot
  70. iPhone 6 Rear Case Replacement: шаг 70, изображение 1 из 1
    • Remove the six remaining Phillips #00 screws from the Lightning connector cable assembly:
    • Two 3.1 mm shoulder screws
    • Two 1.7 mm screws
    • Two 1.5 mm screws
    Спросите у FixBot
  71. iPhone 6 Rear Case Replacement: шаг 71, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 71, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 71, изображение 3 из 3
    • Use the flat end of a spudger to begin peeling the Lightning connector cable assembly up from the rear case.
    Спросите у FixBot
  72. iPhone 6 Rear Case Replacement: шаг 72, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 72, изображение 2 из 2
    • Carefully pull the Lightning connector cable assembly up slightly to free the it from the vibrator and speaker screw posts.
    Спросите у FixBot
  73. iPhone 6 Rear Case Replacement: шаг 73, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 73, изображение 2 из 2
    • Use the flat end of a spudger to lift under the Lightning connector portion of the cable assembly to free more adhesive.
    Спросите у FixBot
  74. iPhone 6 Rear Case Replacement: шаг 74, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 74, изображение 2 из 2
    • Use the point of a spudger to push the microphone portion of the Lightning cable assembly out of its recess in the rear case.
    Спросите у FixBot
  75. iPhone 6 Rear Case Replacement: шаг 75, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 75, изображение 2 из 2
    • Gently run the point of a spudger under the cable assembly between the Lightning connector and the headphone jack to free it from the last of the adhesive.
    Спросите у FixBot
  76. iPhone 6 Rear Case Replacement: шаг 76, изображение 1 из 3 iPhone 6 Rear Case Replacement: шаг 76, изображение 2 из 3 iPhone 6 Rear Case Replacement: шаг 76, изображение 3 из 3
    • Use the tip of a spudger to help guide the headphone jack out of its recess in the rear case.
    • Remove the Lightning connector cable assembly from the iPhone.
    Спросите у FixBot
  77. iPhone 6 Rear Case Replacement: шаг 77, изображение 1 из 1
    • Remove the single 1.7 mm Phillips #00 screw securing the SIM eject lever.
    Спросите у FixBot
  78. iPhone 6 Rear Case Replacement: шаг 78, изображение 1 из 2 iPhone 6 Rear Case Replacement: шаг 78, изображение 2 из 2
    • Remove the SIM eject lever from the rear case.
    • Before reassembling, carefully check your replacement rear case and make sure it contains all the same parts as your original rear case. Transfer any remaining parts before you continue.
    Спросите у FixBot
Заключение
251 человек успешно провели ремонт по этому руководству.
Sam Goldheart
Участник с: 10/18/12
477 664 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
122 членов
Автор 27 554 руководств
38 Комментарии к руководству
My first time inside an iPhone. I slipped on some icy steps and bent my phone. Luckily it bent on the battery side and still worked except for the 'down' volume button. That wouldn't move because the housing was so deformed. Took my time and followed the guide carefully, it was absolutely fine. Took an hour and three quarters.
nbuchan - Ответить Поделиться
My issue is the glue on the battery! i destroyed my first battery saying to remove has anyone got any advice on this? thanks
laurenceleonard - Ответить Поделиться
I failed with both battery pull tabs, but I successfully used a microwaveable wheat bag in place of the iOpener, then carefully slid a store loyalty card under the battery. It took a bit of doing but I just took my time. The back of the battery was a bit bubbled but it still works fine.
I successfully replaced my rear case but upon completion I've noticed my power and volume buttons are no longer clicky in fact they've lost all springiness. I feel like they are constantly touching the button contacts and have yet to turn the phone back on anyone have any ideas as to how to fix this?
csens92 - Ответить Поделиться
In the middle of the volume buttons itself, on the inside is a round plate glued, you have to replace this on the new volume buttons
clbr - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 176
За всё время: 377,763
