iPhone 7 LCD Shield Plate Replacement
Выберете то, что вам нужно
  1. iPhone 7 LCD Shield Plate Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 7 LCD Shield Plate Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 7 LCD Shield Plate Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  4. iPhone 7 LCD Shield Plate Replacement: шаг 4, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 4, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  5. iPhone 7 LCD Shield Plate Replacement: шаг 5, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  6. iPhone 7 LCD Shield Plate Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  7. iPhone 7 LCD Shield Plate Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  8. iPhone 7 LCD Shield Plate Replacement: шаг 8, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 8, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  9. iPhone 7 LCD Shield Plate Replacement: шаг 9, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 9, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Спросите у FixBot
  10. iPhone 7 LCD Shield Plate Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  11. iPhone 7 LCD Shield Plate Replacement: шаг 11, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 11, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  12. iPhone 7 LCD Shield Plate Replacement: шаг 12, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  13. iPhone 7 LCD Shield Plate Replacement: шаг 13, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 13, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  14. iPhone 7 LCD Shield Plate Replacement: шаг 14, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  15. iPhone 7 LCD Shield Plate Replacement: шаг 15, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 15, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  16. iPhone 7 LCD Shield Plate Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    Tri-point Y000 Screwdriver
    $5.99
    Спросите у FixBot
  17. iPhone 7 LCD Shield Plate Replacement: шаг 17, изображение 1 из 1
    • Remove the lower connector bracket.
    Спросите у FixBot
  18. iPhone 7 LCD Shield Plate Replacement: шаг 18, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 18, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Спросите у FixBot
  19. iPhone 7 LCD Shield Plate Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Спросите у FixBot
  20. iPhone 7 LCD Shield Plate Replacement: шаг 20, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 20, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 20, изображение 3 из 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Спросите у FixBot
  21. iPhone 7 LCD Shield Plate Replacement: шаг 21, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Спросите у FixBot
  22. iPhone 7 LCD Shield Plate Replacement: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 7 LCD Shield Plate Replacement, Home/Touch ID Sensor: шаг 23, изображение 1 из 1
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
    Спросите у FixBot
  24. iPhone 7 LCD Shield Plate Replacement: шаг 24, изображение 1 из 1
    • Remove the bracket that secures the home/Touch ID sensor.
    Спросите у FixBot
  25. iPhone 7 LCD Shield Plate Replacement: шаг 25, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 25, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 25, изображение 3 из 3
    Спросите у FixBot
  26. iPhone 7 LCD Shield Plate Replacement: шаг 26, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 26, изображение 2 из 2
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
    Спросите у FixBot
  27. iPhone 7 LCD Shield Plate Replacement: шаг 27, изображение 1 из 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  28. iPhone 7 LCD Shield Plate Replacement: шаг 28, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 28, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 28, изображение 3 из 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
    Спросите у FixBot
  29. iPhone 7 LCD Shield Plate Replacement: шаг 29, изображение 1 из 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
    Спросите у FixBot
  30. iPhone 7 LCD Shield Plate Replacement, Earpiece Speaker: шаг 30, изображение 1 из 1
    • Remove the three Phillips screws securing the earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.7 mm screw
    Спросите у FixBot
  31. iPhone 7 LCD Shield Plate Replacement: шаг 31, изображение 1 из 1
    • Remove the earpiece speaker bracket.
    Спросите у FixBot
  32. iPhone 7 LCD Shield Plate Replacement: шаг 32, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 32, изображение 2 из 2
    • Lift the front facing camera out of the way to access the earpiece speaker.
    Спросите у FixBot
  33. iPhone 7 LCD Shield Plate Replacement: шаг 33, изображение 1 из 1
    • Remove the two Phillips screws securing the earpiece speaker to the front panel:
    • One 1.9 mm screw
    • One 2.5 mm screw
    Спросите у FixBot
  34. iPhone 7 LCD Shield Plate Replacement: шаг 34, изображение 1 из 1
    • Remove the earpiece speaker.
    Спросите у FixBot
  35. iPhone 7 LCD Shield Plate Replacement, Front Camera and Sensor Cable: шаг 35, изображение 1 из 1
    • Reheat your iOpener and apply it to the upper edge of the display assembly to soften the adhesive holding the front camera and sensor assembly in place.
    • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
    Спросите у FixBot
  36. iPhone 7 LCD Shield Plate Replacement: шаг 36, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 36, изображение 2 из 2
    • Use a spudger to gently pry the ambient light sensor out of its recess on the front panel.
    • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
    Спросите у FixBot
  37. iPhone 7 LCD Shield Plate Replacement: шаг 37, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 37, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 37, изображение 3 из 3
    • Slide the pick towards the front facing camera housing, separating the adhesive holding the cable to the front panel. Stop just before the screw posts.
    Спросите у FixBot
  38. iPhone 7 LCD Shield Plate Replacement: шаг 38, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 38, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 38, изображение 3 из 3
    • Use the pick to lift the camera cable up off of the two plastic posts on the front panel and separate it from the last of the adhesive.
    Спросите у FixBot
  39. iPhone 7 LCD Shield Plate Replacement: шаг 39, изображение 1 из 1
    • Remove the front camera and sensor cable.
    Спросите у FixBot
  40. iPhone 7 LCD Shield Plate Replacement, LCD Shield Plate: шаг 40, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement, LCD Shield Plate: шаг 40, изображение 2 из 2
    • Remove the three 1.2mm tri-point Y000 screws from either side of the display assembly for a total of six screws.
    Спросите у FixBot
  41. iPhone 7 LCD Shield Plate Replacement: шаг 41, изображение 1 из 1
    • Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
    Спросите у FixBot
  42. iPhone 7 LCD Shield Plate Replacement: шаг 42, изображение 1 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 42, изображение 2 из 3 iPhone 7 LCD Shield Plate Replacement: шаг 42, изображение 3 из 3
    • Use an opening pick to break up the adhesive near the home button that holds the LCD shield plate to the display assembly.
    Спросите у FixBot
  43. iPhone 7 LCD Shield Plate Replacement: шаг 43, изображение 1 из 2 iPhone 7 LCD Shield Plate Replacement: шаг 43, изображение 2 из 2
    • Gently lift the LCD shield plate from the display assembly.
    • Be careful not to snag the display data cables when removing the LCD shield plate.
    Спросите у FixBot
Заключение
99 человек успешно провели ремонт по этому руководству.
Evan Noronha
Участник с: 02/05/15
229 556 Репутация
Автор 168 руководств
6 Комментарии к руководству
Awesome Guide! Very easy to follow!!! Thanks!
apriltanner1975 - Ответить Поделиться
Use a good tri-point screwdriver for this repair. Some of the screws are very tight!
Robin Vandenbroucke - Ответить Поделиться
Absolutely true. The cheap Y000 driver that came with a repair kit was stripped to uselessness by the time I got to the shield screws.
Mike Sorice - Ответить Поделиться
I am a better technician because ifixit repair guide have made it easier for me. Thank you
Agba - Ответить Поделиться
I had a lot of trouble getting the home button cable connector back after replacing the screen and shield. I wound up disconnecting the shield to give the screen side of that connection a little more play and enable the connection to be made.
Incidentally, if you want to take off just the shield itself and not the outer cables, you can skip 19-35, except the outer orange screws in 19 and the outer orange screws in 26. It might make getting under the shield adhesive harder, but in the case I described above, it was quite useful!
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 30
За последние 30 дней: 165
За всё время: 89,397
