iPhone 8 Plus Taptic Engine Replacement
Выберете то, что вам нужно
    1. iPhone 8 Plus Taptic Engine Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Спросите у FixBot
      Добавить комментарий
    1. iPhone 8 Plus Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Спросите у FixBot
    1. iPhone 8 Plus Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Спросите у FixBot
    2. iPhone 8 Plus Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Спросите у FixBot
    3. iPhone 8 Plus Taptic Engine Replacement: шаг 5, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 5, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 5, изображение 3 из 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Спросите у FixBot
    4. iPhone 8 Plus Taptic Engine Replacement: шаг 6, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 6, изображение 2 из 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Спросите у FixBot
    5. iPhone 8 Plus Taptic Engine Replacement: шаг 7, изображение 1 из 1
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
      Спросите у FixBot
    6. iPhone 8 Plus Taptic Engine Replacement: шаг 8, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 8, изображение 2 из 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Спросите у FixBot
    7. iPhone 8 Plus Taptic Engine Replacement: шаг 9, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 9, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 9, изображение 3 из 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • Insert an opening pick or other thin pry tool a few millimeters into the gap.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Спросите у FixBot
    8. iPhone 8 Plus Taptic Engine Replacement: шаг 10, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 10, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 10, изображение 3 из 3
      • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      Спросите у FixBot
    9. iPhone 8 Plus Taptic Engine Replacement, Screen information: шаг 11, изображение 1 из 1
      • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
      Спросите у FixBot
    10. iPhone 8 Plus Taptic Engine Replacement: шаг 12, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 12, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 12, изображение 3 из 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Спросите у FixBot
    11. iPhone 8 Plus Taptic Engine Replacement: шаг 13, изображение 1 из 1
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      Спросите у FixBot
    12. iPhone 8 Plus Taptic Engine Replacement: шаг 14, изображение 1 из 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Спросите у FixBot
    13. iPhone 8 Plus Taptic Engine Replacement: шаг 15, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 15, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 15, изображение 3 из 3
      • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
      Спросите у FixBot
    14. iPhone 8 Plus Taptic Engine Replacement: шаг 16, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 16, изображение 2 из 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Спросите у FixBot
    15. iPhone 8 Plus Taptic Engine Replacement: шаг 17, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 17, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 17, изображение 3 из 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Спросите у FixBot
    1. iPhone 8 Plus Taptic Engine Replacement, Battery Disconnection: шаг 18, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement, Battery Disconnection: шаг 18, изображение 2 из 2
      Magnetic Project Mat
      $19.95
      • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
      • Two 1.3 mm screws
      • One 1.4 mm screw
      • One 2.7 mm screw
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      Спросите у FixBot
    2. iPhone 8 Plus Taptic Engine Replacement: шаг 19, изображение 1 из 1
      • Remove the lower display cable bracket.
      Спросите у FixBot
    3. iPhone 8 Plus Taptic Engine Replacement: шаг 20, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 20, изображение 2 из 2
      • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Спросите у FixBot
    1. iPhone 8 Plus Taptic Engine Replacement, Display Assembly: шаг 21, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement, Display Assembly: шаг 21, изображение 2 из 2
      • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
      • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      Спросите у FixBot
    2. iPhone 8 Plus Taptic Engine Replacement: шаг 22, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 22, изображение 2 из 2
      • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
      Спросите у FixBot
    3. iPhone 8 Plus Taptic Engine Replacement: шаг 23, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 23, изображение 2 из 2
      • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
      • One 1.0 mm screw
      • One 1.2 mm screw
      Спросите у FixBot
    4. iPhone 8 Plus Taptic Engine Replacement: шаг 24, изображение 1 из 1
      • Remove the bracket covering the front panel sensor assembly connector.
      Спросите у FixBot
    5. iPhone 8 Plus Taptic Engine Replacement: шаг 25, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 25, изображение 2 из 2
      • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
      Спросите у FixBot
    6. iPhone 8 Plus Taptic Engine Replacement: шаг 26, изображение 1 из 1
      Спросите у FixBot
    1. iPhone 8 Plus Taptic Engine Replacement, Wi-Fi Diversity Antenna: шаг 27, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement, Wi-Fi Diversity Antenna: шаг 27, изображение 2 из 2
      • Remove the three screws securing the L-shaped bracket next to the Taptic Engine:
      • One 1.3 mm Y000 screw
      • One 2.6 mm Phillips screw
      • One 3.5 mm Phillips screw
      Спросите у FixBot
    2. iPhone 8 Plus Taptic Engine Replacement: шаг 28, изображение 1 из 1
      • Remove the bracket.
      Спросите у FixBot
    3. iPhone 8 Plus Taptic Engine Replacement: шаг 29, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 29, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 29, изображение 3 из 3
      • Use an opening pick to gently separate the adhered portion of the antenna flex cable from the top surface of the speaker.
      • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This makes it easier to separate (and re-adhere) the flex cable safely.
      Спросите у FixBot
    4. iPhone 8 Plus Taptic Engine Replacement: шаг 30, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 30, изображение 2 из 2
      • Use the point of a spudger to pry up and disconnect the antenna flex cable from the logic board.
      Спросите у FixBot
    5. iPhone 8 Plus Taptic Engine Replacement: шаг 31, изображение 1 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 31, изображение 2 из 3 iPhone 8 Plus Taptic Engine Replacement: шаг 31, изображение 3 из 3
      • Use the point of your spudger to pry up and disconnect the other end of the antenna flex cable from its socket, next to the Lightning Port.
      • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press down on the connector with the flat of your spudger until it clicks into place.
      Спросите у FixBot
    6. iPhone 8 Plus Taptic Engine Replacement: шаг 32, изображение 1 из 1
      • Remove the Wi-Fi diversity antenna.
      Спросите у FixBot
    1. iPhone 8 Plus Taptic Engine Replacement, Taptic Engine: шаг 33, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement, Taptic Engine: шаг 33, изображение 2 из 2
      Standoff Screwdriver for iPhones
      $5.49
      • Remove the three screws securing the Taptic Engine:
      • Two 1.5 mm Phillips screws
      • One 2.4 mm standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Спросите у FixBot
    2. iPhone 8 Plus Taptic Engine Replacement: шаг 34, изображение 1 из 2 iPhone 8 Plus Taptic Engine Replacement: шаг 34, изображение 2 из 2
      • Use the point of your spudger to pry up and disconnect the Taptic Engine flex cable.
      Спросите у FixBot
    3. iPhone 8 Plus Taptic Engine Replacement: шаг 35, изображение 1 из 1
      • Remove the Taptic Engine.
      Спросите у FixBot
Заключение
23 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
453 897 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 49 298 руководств
6 Комментарии к руководству
Hello
Thank you for the guide. I have read that it is possible to transfer the vibrating motor data from the original taptic engine. Do you know what difference it makes whether or not the data is transferred?
Thanks in advance for your help.
Best regards
thalley - Ответить Поделиться
After that , printfinger will work ?
Mohamed Ali - Ответить Поделиться
This guide was very helpful! I ended up just needing to tighten the screws retaining the Taptic Engine rather than replacing the whole thing, but this guide got me to that point! Thank you!
Nick - Ответить Поделиться
iPhone had back glass crack and vibration feedback from the haptic engine and thought “dang, engine must be messed up from being dropped and cracked”. Well looking online and seeing common issues with “screws being lose”, I figured… Let us tackle this fix. 10 minutes later, screen is removed carefully and professionally and 2 screws were sliding around in the phone with 2 more barley holding the engine. Screwed in. Phone haptic is feeling good as new :D
Jonathan - Ответить Поделиться
Is it true that you cannot replace the engine? It have heard it will not work without some kind of data transfer? I broke the flex during a repair and need an answer!
Mohammad Ali - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 38
За последние 30 дней: 139
За всё время: 46,853
