Введение
Перейти к шагу 1Follow the steps in this guide in order to gain access to components found inside the device which most often require repair of replacement.
Выберете то, что вам нужно
Инструменты
Remove the battery compartment cover.
Remove the battery.
Locate the interlocking pegs along the seam of the device's casings.
Gently pry the pegs apart one at a time, working your way around the case.
The battery contact springs may prevent the case from separating.
Push the battery contact springs down through the hole in the case.
The casing protecting the USB and headphone jacks must be removed.
Locate and gently pry apart the two interlocking clips holding it in place.
The outer casings may now be removed and the MP3 player should separate.
