Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
Вопросов 20 Показать все
Guides for or repair/replacement instructions
I have seen that you don't (currently) provide a step-by-step guide for repair or component/parts replacement for the 24" iMacs, why is that?
I'll need it because I have to replace my failed (stock) HD [hard disk] with a new, larger one.
Many kind regards, Dave.
Это хороший вопрос?
Оценка 6
6 Комментариев
I have an iMac 24" referred to as a model 9,1 in the about this mac section. I can't find the EMC number anywhere.
из
Look on the bottom of the stand.
из
Hi, can anyone know how to replace an HDD with the iMac 27-inch 2011, please?
из
take a look at the guides at the top of the page or under the photo of the mac. i know there isn't a guide for 2011 on there but there are many similarities for getting into these machines. Read through the guide for the 24" or 27" from last model and see if you can work it out. Otherwise you may find some unpublished guides from one of the users called "mayer"..he has also left his contact information on his profile page.
из
I have just completed a step-by-step guide to replacing the hard drive. Let me know if you have any questions on the process. If it helps you replace your hard drive please make sure to give me credit for answering your question. Thanks, and good luck.
из
Показать 1 больше комментариев
Добавить комментарий
Ответов (3)
Выбранное решение
Fair question. The most obvious reason is that we don't have a 24" iMac to write the guides with!
Also, writing guides is quite time consuming for us, and getting all of the iMac guides we have took us quite a while. We're taking a break from writing these guides until we see what customer demand is for the parts we've already got. The best way to get us to write more guides is to buy parts!
That said, we do sell the part you need. You can use this drive just fine.
We'd love it if anyone out there wants to write manuals for this device. Let me know if you're interested. Going forward, we'll be enabling people to add more and more repair content to augment ours.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Well, I'd sure like a guide for the 24" EMC 2267.
из
Here is what I did to install my new 2TB SATA drive..
All the steps listed for the 20" work fine up until..
Step 4 note that there are 3 different sizes of screws.
At step 10 follow my instructions below.
- First I covered the iSIte camera with a piece of scotch tape to keep dust out. There is a lot of dust under the LCD panel. I used a can of air to blow it all out which made a big mess and means I'll have to clean the LCD panel.
- Lift the left side of the LCD like it shows you but instead of 4 connector cables for the inverter you will see that there is a large back cable that runs from an analog board to the display. Now look toward the center of the iMac and you will see the hard drive. You want to expose the hard drive and mount.
- Lift the LCD panel enough to clear the black frame then rotate it enough so you have access to the hard drive then set it down. In my case a corner of the LCD panel sat on the black plastic frame of the iMac.
- Gently remove the temperature sensor on the hard drive because you want to put it back on the new hard drive.
- Now grasp the black handle on the hard drive mount and pull toward the hard drive. The hard drive mount will pull up and away from the iMac.
- Disconnect the SATA data and power cables from the hard drive.
- Remove the old drive from the mount (2 screws and 2 post screws) put the new hard drive in and reverse all instructions.
If you covered the iSite camera with a piece of tape don't forget to remove it.
Hope that helps.
Alan
Оценка 2
1 Комментарий:
Thanks Alan, I'm going to give it a go with the 20" iMac instructions, amended as per your post. Appreciated!
Cheers,
Phil
из
You can use the 20" EMC 2133 and 2210 guide for reference to access the hard drive (the machines are reasonably, but not entirely similar).
Оценка 1
Добавьте свой ответ
DaveFlash будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 6
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 57,083
