Can I add a bluetooth card to this machine
there is a bluetooth port but no card blue tooth ant sign above F1 but no function switch icon at f2 or anyware else can I still upgrade this machine?
Это хороший вопрос?
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Это хороший вопрос?
robert, enter the service tag from your computer on this site. It should provide you with a list of components and options for your individual computer. Hope this helps, good luck.
Был ли этот ответ полезен?
Isn't a bluetooth already there in Dell's build up. I have a Vostro and bluetooth is built-in inside. Latitude is an old model, I suppose, you have to look into Dell Store for sure or I think a local technician may also help you out.
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 454
3 Комментариев
the laptop didnot have blue tooth when i got it i did inspection of it and it has the port just want to know if i can upgrade it
из robert
Do you have the slot labeled WPAN/UWB/FCM on your motherboard?
из oldturkey03
yes port has small blue wire at it
из robert
