Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Satellite C660 is a series of laptops released by Toshiba around 2010. They have 15.6-inch screens and a variety of Intel processors.
Вопросов 20 Показать все
My laptop not showing anything on display.
My laptop cannot show anything on the screen and the fan is not spinning but the power-led is on. What is the possible problem of this.
Это хороший вопрос?
Оценка 7
5 Комментариев:
try an external monitor first and see if it shows anything.
из
Same problem. Black screen, no sound but fan noise. Both leds green.
I hope mobo is still alive. I'll try to reset BIOS removing little battery.
из
Try re-seating the Memory. If the fan is spinning up abnormal loud try to re-seat the Cpu.
из
I have the same problem. It powers up with a blank screen, fan goes on, then suddenly it powers out.
из
Ditto here. I see the fan is not spinning because I took the keyboard out. I have removed memory, HDD, plugged into external monitor... nothing.
из
Добавить комментарий
Ответов (4)
My screen is blink nothing showing
Был ли этот ответ полезен?
Оценка 0
My screen is black and I do not have a fan sound
Оценка 0
1 Комментарий:
Ditto! I have pulled out the memory, HDD, keyboard, hooked up to external monitor and nothing. When I power on, I get two LEDs on in the front, but I can see the fan doesn't move (because keyboard is removed). I am going to replace CMOS batt... maybe that is the problem?
из
My laptop says reboot reboot
Оценка 0
toshiba motherbore c660 gone what can i do to reply it
Оценка 0
Добавьте свой ответ
Kellin будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 2,833
