Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
A laptop by Toshiba with a 15.8" display and runs Windows. Has a straightforward repair similar to most laptops. Requires only a screwdriver.
Вопросов 3 Показать все
K O'd my laptop
In a fit of rage and stupidity ,I slammed my laptop closed and now it is inoperable. I have a windows Vista factory out of the box recovery program but it will not recover. It will load first disc and second disc but 32% through the recovery it has an error and shuts laptop down. Do I need a replacement laptop along with anger management ? Lol
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Hi Ebert, While the machine is running, place your ear next to the machine and listen for any signs of hard drive failure. Provided you have a mechanical hard drive, sounds of spinning up, clicking/clunking and then spinning up again, etc. may be signs that you accidentally damaged the hard drive. A healthy mechanical hard drive has somewhat of a chattering/popping sound. Also--depending on just how hard it was slammed--It may be a good idea to 're-seat' the memory, as a poorly seated chip may become partly dislodged in the even of jarring. Start there, and please let us know how it goes.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Ebert Williams будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 304
