Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Epson WorkForce 645 is an all-in-one office color inkjet printer. Model: C11CB86201.
Вопросов 20 Показать все
changed cartridge and now the printer is stuck on Cleaning Head
Change the cartridge but it won't print. IT keeps saying "cleaning head and I'm losing inks. I have lost 3 cartridge already, it just keeps draining all my ink and not printing.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
robr389@gmail.com
This is a common problem with this printer. The inkjets have the tendency to clog, especially if you are not using the printer often, or even if you are using it often, but only printing black. Normally the "Head Cleaning" maintenance routine will clear the jet head. However, the cleaning process always takes an unacceptable amount of ink and in your case (and mine at this moment) the cleaning routine makes no improvement. Regardless of the routines failure, it still uses more ink than any normal person can afford. I am researching the issue and will post any helpful info I can find.
Был ли этот ответ полезен?
Оценка 0
Here is a guide with several methods to clean your Epson printer in ascending order of ruthlessness :)
http://www.ebay.co.uk/gds/How-to-unblock...
Оценка 0
Добавьте свой ответ
Sandra Ladson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,200
