Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Вопросов 20 Показать все
Touch Screen acting on its own after screen replacement.
I own a local repair shop and this dreaded issue is back! The ipad mini 1,2 had this issue of the ipad touch screen acting crazy on its own as if someone was opening and closing apps. A simple solution solved that issue with Kapton tape.
This solution was applied to the ipad mini 3 screen but does not solve the crazy/acting on its own touch screen issue.
Does anyone know a solution to this issue. I've tried everything. Kapton tape on the lower section of the screen covering both home button cable and coving the the outside of the inside edge of the touch sensor. no aid.
Это хороший вопрос?
Оценка 1
4 Комментариев:
Have you tried putting Kapton tape around the edges as shown on the arrow but instead around the whole thing (probably over kill but might be worth a try.
Like this: https://d3nevzfk7ii3be.cloudfront.net/ig...
из
Yes, we have tried that, We put kapton around the whole thing. Still have the same issues. Thanks
из
Did you check the connectors for the digitizer? I would clean both ends of the connection and try again.
из
Yes, we do micro soldering so we have see when the connector pins get pulled out. The issue is we have seen this on many iPad mini 3's not just one repair we have done. Almost all the ipad mini 3's we repair test working then we get an email or call from a customer stating the touch screen is going crazy.
из
Добавить комментарий
Ответов (1)
This turned out to be a software issue on my sons iPad. Initially when turned on it was ok, then after a few seconds to a minute it would go crazy with random screen presses and swipes.
Fix was to uninstall you tube app, then reinstall. This removed a pending update icon on the App Store app that was stuck. I had restricted you tube in the settings, which seems to have prevented an automated update and caused some sort of bug.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Chris будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 114
