Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Asus Transformer Pad TF103C is a 10.1 inch Android hybrid tablet released in June 2014. It is specifically for entertainment use with wifi ability.
Вопросов 13 Показать все
Touch screen not working
Hi,
I'm having issues with my Asus tablet running Android Lollipop. For the past few months, the touchscreen would stop working momentarily, then everything would come back to normal after a few restarts. It was more likely to happen when the tablet was charging though. At some point I found a weird hack that was plugging the tablet for a second every time it happened.
Now for the past few days, this would work and the tablet is now useless without its keyboard. I've read on some forums that the Battery Saver app could be the cause. Indeed I noticed a bug with it because every time the tablet was charging I would get a notification saying that an app was drawing too much power, but the Battery Saver app would crash every time I tried to open the notification.
Last night, I disabled the power saving mode and rebooted the tablet (as suggested in the forums) but it didn't do the trick.
This morning, I tried to reset the tablet both via the settings menu and recovery mode, but then touch screen is not working. I also tried to "swipe cache partition" but none of this would work.
Is there anything else I could try? I'm not sure if it's a hardware or a software issue, but as far as I remember the tablet has not received any impact in particular and there's no scratch at all on the screen.
Thanks
Это хороший вопрос?
Оценка 4
8 Комментариев
I have exactly the same problem, did you find a solution? thanks in advance.
из
No, and this will make me think twice before buying other Asus products.
из
I used to have the same issue and the I used to dindn't mean that the issue was fixed what happen to me is the tablet is now completely dead, very disappointed about asus a brand that I used to love but the quality is so bad now, in other hand lenovo products are super cheap now and durable too, by the way I'm an IT guy and I handle this kind of products every day
из
Hello,I have same problen and I find the system repair program from Google Play(that brown logo).Then I was ran the program,I put the device to factory setting.Then it start the work.It works untill now I typing tekst.Good day.
из
Hello agen.Notice that programs that you installa on Asus transformer Pad,can make issues to it.My ATP:s screen touch stops working and I delete all new programs on it.Good luck.
из
Показать 3 больше комментариев
Добавить комментарий
Ответов (9)
Наиболее полезный ответ
Actually, my cable solution only worked for a short period, then it stopped again. So I tried the pigtails to the screen, as per Rod H's post. But again, it still only worked for a week or so.
Then I had a think about the connections to the screen: they come into the same small sub-board as the USB connection, and both the USB power/signals and the touch screen signals go through another pig tail connector to the main board.
I thought that it is possible that the movement of the plugging and unplugging of the USB (as per Andre's original post) might disturb the connectors.
So I reseated the pigtail connector going to the main board as well. That was over a month ago, and the problem has not come back.
I hope this works for you as well.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thanks for the video, it seems to work now. I think you should create your own answer instead of a comment
из
It only worked for a few minutes for me.
из
See my message in one of the other threads about the same issue, same model
Оценка 0
2 Комментариев:
do you have a link to that?
из
Why won't my touch screen work
Sorry for late reply, Ifixit didn't inform me about your question. You can always click on a user's icon to see their contributions
из
I just found in another post that the digitizer cable can come loose or detached from heat
Оценка 0
3 Комментариев:
No, it"s definitely a software issue. I'm able to use it after I play with the charger (plug/unplug/sleep/wake)
из
Only if you can replicate both the problem and the way to fix it, you can be sure that it's (in your case) either a hardware or a software problem. There are people who have a dead touchscreen each time after wake up from sleep and revive it using a cold reboot.
In my case such a solution or for example draining and recharging the battery sometimes seem to work... but more likely it's simply the mechanical handling (laying down, closing screen on keyboard, connecting, disconnecting that might or might not accidentally make or break the delicate loose connection . Because in my case it does work 100% of the time to open the back and press the flatcable firm into its slot. It keeps coming loose from time to time so perhaps I should fixate it , hot glue or so?
из
I've seen other people mentioning this issue on other forums. I'll try flashing the tablet again and see how it goes. Again, I'm 99.999% it's a software issue. Even the Windows version of the tablet has this, but it's easier to fix (with a few tweaks in the Windows settings that unfortunately Android doesn't have).
из
I also found this issue with a TF103C tablet. I opened the case and re-seated the screen pig-tails and the screen became fully responsive. Then some time later the screen was again unresponsive. I'd read that a static buildup on the screen can cause the screen to become unresponsive so I opened the back but this time just touched the screen pigtail connector rather than re-seating the connector. Again the screen regained its touch control. I think there's something to the static build-up theory and will use that fix in the future.
Оценка 0
4 Комментариев:
Is there a tutorial or something on how to open it? I'm not really comfortable with it, how hard is it for someone who has never opened a tablet or a phone?
из
Interesting​. Can you show the cable to play with? Is it easy to reach? Thanks
из
Are you think programs that you install it?My opinion is that if you download lot of programs that is not optimise your pad,then it can bad.
из
where the finger points
Оценка 0
1 Комментарий:
So should I just touch it?
из
Well, I swapped in a digitizer/screen (unplugged the old one and plugged in a new one that I left on the desk) and it made no difference on mine
Оценка 0
Hello.
I fixed this by:
a) Powering off
b) Opening the back cover
c) Disconnecting the battery for about 10 secconds
d) Re-connecting the battery
e) Restarting.
Thanks.
BC
Оценка 0
1 Комментарий:
Thanks so much. I followed your advice to the letter, after which I was able to use the touch-screen to full effect. Thanks again :)
из
Hi. I had this problem too. I bought this tablet 2days ago as used. And it started no responsing after first charge.
Result from reading different forums - disconnect flex cable from docking connector inside tablet.
Also re-connect, just for sure, touch/screen double flex cable (on right side down under silver tape).
I am using it as a tablet without docking to keyboard. Therfore such solution.
Оценка 0
Connect keyboard via keyboard slot or via USB and turn off Power saver in Settings and touch will work again
Оценка 0
Добавьте свой ответ
Andre будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 34
За всё время: 36,815
