How do I reconnect a broken iSight cable?
As the photo shows, I wonder how do I connect them back in correct sequence, black-white-green-red?
Это хороший вопрос?
Это хороший вопрос?
Kyle, that's the the iSight/Mic board, looking at the inside top of the the iMac bezel. The cut cable is most likely the mini USB feed.
Unfortunately, I haven't yet located a good pic showing these wires - as there is shield foil over the connection normally.
I did find the whole part available on eBay here: http://cgi.ebay.co.uk/iMac-G5-17%22-iSig...
Good Luck!
Был ли этот ответ полезен?
with the cables on the left and the camera lense pointing away from you there will be 4 contact points on the left side of the board this where the cables connect starting at the top, on the top edge where the isight lens is the order is as follows
black
white
green
red
hope that helps!
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,320
1 Комментарий
That doesn't look like any iSight that I'm familiar with. What device is this a photo of?
из Kyle Wiens
