Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
MacBook doesn't power on
Hello people.
My MB doesn't boot anymore. Whether on battery or on MagSafe, it doesn't power on.
I managed to change the DC-In board, but still doesn't power on. MagSafe is working OK because it's from an other MB.
What's the next step I should take? Is the MoBo TFU?
Thanks and kind regards,
Flavio.
Update
Hello Rick, and thanks for replying.
MagSafe lights up green, but it's not a "calm and fixed" green. It is a flickering green light.
About the battery: should I watch under the MacBook if the battery LEDs light up when I press the power-on button on the MacBook itself?
I'll eventually be trying to reset the PRAM, as a next step.
Thanks so far.
F.
Это хороший вопрос?
Оценка 1
1 Комментарий
Please tell us what you DO get, lights, sounds?
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
There are a few issues that might cause a MacBook to not boot up like you're experiencing, such as a damaged power button on the top case (sometimes due to spill damage), a bad logic board, or other various small issues. Does the MagSafe light illuminate when plugged into the DC-in board? Is the battery receiving power (the level indicator should light up when the button is pressed)? Have you tried resetting the PMU/SMC by holding down the power button for 10 seconds while the machine is connected to AC power? You should see the sleep light flicker and hear a tone. If that doesn't work, you might want to try resetting the PRAM. Hope this helps!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Piramide Informatica будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,368
