Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Lapttop not connecting to projector screen
My laptop has stopped working with the projector. The projector works with another laptop. What is on my laptop desktop does not display on the projector screen. Tried holding down the FN key with all the other F keys.
Это хороший вопрос?
Оценка 0
3 Комментариев:
What model is your projector?
из
It is an Optoma. My friend's laptop is working fine with it.
из
My laptop has worked with this projector many times before. Today is the first time I have had this problem.
из
Добавить комментарий
Ответов (1)
You said your projector is worked on another laptop, so the projector is find, so i think this laptop maybe had no projector driver. So try to connect the projector to the laptop, check all the port and then enter the device manager, try to install the projector at first. And you can view here to learn how to install drivers. If the two laptops has the different system, you'd better see the system this projector support. Because some old projector maybe not supports windows 8, windows 10.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Found out from a kid that all I needed to do was go to control panel display and it select play on another screen.
из
Добавьте свой ответ
harobed1170 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 1,458
