Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Вопросов 20 Показать все
iPad mini 2 error 4014
Hi Team,I have a ipad A1489 to remove icloud, I downloaded the nand did reballing and reassembled a board but it did not return a lightning, changed a new nand and the error itself, it given to erase everything with IPB2 and error itself. Please help me solve this problem. I have several iPad with them.
Это хороший вопрос?
Оценка 3
2 Комментариев
i have the same problem ! any help ??
из
i have the same problem. i think it has something to do with a triger when you remove the NAND
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Put simply, the error is hardware related, but like all things digital, you don’t really get to fix this one without your share of head-banging. There are a variety of solutions that worked for various people. What we try here is to make sure you don’t go about trying them randomly but in an ordered way. That makes it easier to fix.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I agree with you!!
из
Добавьте свой ответ
Johannes Moreno будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,164
