Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Dell Inspiron 15R 5520 laptop features a 14.88" screen, brushed aluminum finish and features a i5 core processor .
Вопросов 12 Показать все
Broken Headphone jack. Is it fixable>
Long story short, I broke my headphone jack on my Dell Inspiron 5520 a while ago and today was the last straw. Is it possible to replace the entire jack without doing and soldering? Here's the part and I dont know if it just sits in place or if it requires soldering.
https://www.aliexpress.com/item/Audio-Ja...
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Hi!
The broken headphone jack needs to de-soldered from the motherboard and replaced with the new one, that needs to be soldered back on. At the same time you need to use a special soldering iron (or a very good one) to melt the solder. Also, laptop boards are very complex and usually multi-layered, therefore using a soldering iron could break some traces or parts on the other side with no visible damage, aggravating the problem. A more elegant solution would be replacing the entire board or even taking it to a computer repair shop.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Desmond Waters будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 349
