Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Toshiba Satellite A665-S6094 is a laptop computer.
Вопросов 3 Показать все
Jus restored my toshiba laptop,what now?
I just restored my Toshiba a65 s6094 laptop because it had Wi-Fi connection but no internet connection. So now that I have done that it still has no internet connection so what should I do???
Это хороший вопрос?
Оценка 0
1 Комментарий:
Look up the laptop on Toshiba's website download the wifi module drivers and install then restart the laptop.
из
Добавить комментарий
Ответов (1)
If it is connecting to your wi-fi but has no internet that is not a problem that resetting the PC would help. Have you tried running the network help to see if it can fix it. It may be you just need a new IP address from your router. Also are other devices connecting to your Wi-Fi and getting internet, it might be your connection.
Был ли этот ответ полезен?
Оценка 0
6 Комментариев:
Limited knowledge don't know how to run test I've done nothing afraid change something wrong. So Wat do I do wit the IP Adrea's if I get it. Yes other devices are fine. Thank for the help please help more I know basically 00.
из
On your task bar right click the internet connection icon. It should give you a couple choices. Click trouble shoot this should give you an idea of what is wrong and might even fix it for you.
из
Mine said repair is the same?
из
Said renew IP address
из
The troubleshooter says internet connection sharing troubleshooter but there's about five to six more troubleshooters also I don't know anything about the sharing when I push down on it did I ask a bunch of questions about cables and wires and I'm on a wireless connection it asked if I was on AOL DSL how was using a modem a cable and I don't know the answer to any of that I'm sorry
из
Показать 1 больше комментариев
Добавьте свой ответ
Iammdcyo будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 168
