Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Released in October of 2003, Sony's Cyber-shot DSC-T1 is an ultra compact camera with many great features all in a package about the size of a deck of playing cards.
Вопросов 6 Показать все
Misplaced Pin on Sony DSC-T1 Repair
Hi Great guide on repairing the DSC-T1's components. When I opened the front cover a small pin fell out. It is about 11mm long and the shaft is about 1mm in diameter. I do not see it pictured in any of your photos and I can't find where it goes. The camera seems to work without it, but I'd really like to know where it goes.
Thanks for your help.
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (4)
Выбранное решение
Sean Mann I placed the complete level 1-level 3 service manuals for you to download. It will show you everything you ever wanted to know about your camera. May be you find the "spare part :-) " and its location. Good Luck
Level 1
Level 2
Level 3
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
Thanks a ton man!!
из
You are welcome ;-)
из
Thanks to Old Turkey I can tell you that it's a "lens pin" and it goes into the lens/CCD assembly, just under the one motor.
On the other hand I can't tell you what it does. Looks like it just lies in there loose, doesn't hold anything, doesn't touch anything (except the front and back covers, looks like).
All I can think of is maybe it's a spacer to keep the body from denting in the middle. Anyway, mine's in and all is good. Thanks Old Turkey!
из
Have you foumd where this goes - same problem?
Оценка 0
1 Комментарий:
is it a pin for the strap to be tied to?
из
it looks like the axel rod with spring of the battery door. i have this camera to repair the ccd sensor. everything its working but i can´t get images comming through the lens thanks for the ifixit site
Оценка 0
I have a Sony DSC-T1 Cyber-shot - Digital Camera - 5.1 MegaPixel - DSC-T1. I haven't used it in a year. I just connected the cable charger to get it to work. ASll I'm getting is a window with the clock set options. I've reset the camera. However, I'm unable to use all other functions. Do you think I need a new battery?
Оценка 0
Добавьте свой ответ
Sean Mann будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,837
