Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Visual Land Prestige Elite 8Q is an 8-inch Android tablet produced by Visual Land.
Вопросов 20 Показать все
It runs slow all the time
Please tell me how I can get my Visual Land Pretige Elite 8Q tablet to run faster
Update (10/01/2018)
Hello can you please help me with this problem I'm having
Это хороший вопрос?
Оценка 0
4 Комментариев:
Hi,
Try going to Home>Settings>Device>Apps > Running to check how many apps are running in the background.
If they are "downloaded apps" try stopping them (long press on the app to get options) and check if performance improves.
Do not stop any system apps as the tablet may become unresponsive and will have to be force shutdown - long press of Power button
If unsure if apps are downloaded by you or system apps pre-installed, check in the Downloaded apps section Home>Settings>Device>Apps > Downloaded to see if they appear there
из
Please can you help me my visual land prestige run so slow how can I get it to faster
из
@Ann Sullivan
Check the comment above and see if trying that improves performance
из
what if the tablet is brand new?
из
Добавить комментарий
Ответов (1)
Don’t be tempted to keep ‘Cleaner’ type apps running in the background. Install a good one, like Ccleaner, clean out your tablet and uninstall that app when finished. If you just want to give your tablet a quick clean to improve performance go into your settings and find Storage, then clear CACHE only. Get an SD Card, Class 1 (or 10) at least, and change settings to store pictures and other stuff there instead of on your Internal Storage. You might even be able to transfer apps you have installed to that SD Card if your settings allow for that. Certain games demand a lot of your tablets resources even when you aren’t playing them - so install an app called Greenify - this will allow you to force close multiple apps you don’t want to have running in the background while doing other things. Greenify will force close apps you preselect when the tablet goes to sleep, or when you tap on the Greenify Widget.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Beatrice Castro будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 2,072
