Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
How to get my data from hdd?
Hello,
I have MacBook Pro 2011 and after the logic board problem I can't log to my MBP ! I have very important data on it!
Now I have a PC with windows 10 how I can get my data again ?
Note: The MBP had a password when it's work properly.
Это хороший вопрос?
Оценка 0
4 Комментариев
This just make internal hard disk as external hdd I have tool like this.
The problem is: I can't see my files in hdd Because the OS is different.
Thank you for answer.
из
Hi @aligraphics ,
There's info online that shows how to read mac files using Windows. ;-)
из
Thank you so much, I made it before this but I can't see my data only system files exist!
из
Hi @aligraphics .
You can try this and see if it works. It says that there is a free 5 day trial before you have to buy it ;-)
из
Добавить комментарий
Ответов (1)
Выбранное решение
Buy the enclosure here and transfer your MacBook Pros hard drive into the enclosure. Plug the enclosure into your new computer and you can retrieve the files thru there.
https://www.amazon.com/AmazonBasics-2-5-...
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Ali будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 71
