Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
Вопросов 20 Показать все
Why is my keyboard and trackpad behaving like this?
I have a macbook air that I’m currently trying to fix that has an issue with the trackpad and the keyboard, where randomly the trackpad will only do right clicks and the keyboard will act like it’s completely out of wack.
By “out of wack” I mean that buttons seem to be doing other buttons, pressing letters when trying to type in text fields will make the f*ck off noise (for lack of a better term) and keys like H will backspace, and the enter key will start putting letters.
Sorry for the poor explanation but I really don’t know how else to explain it.
We have reset the preferences, looked through the preferences, reset PRAM, reset SMC, used different user accounts. This also happens when you use an external mouse and keyboard so it doesn’t seem to be a hardware issue. I don’t know too much about macs and their operating system so I’m kind of stabbing in the dark here, any advice would be awesome.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Выбранное решение
It sounds like the system had either a liquid spill or the battery swelled, so the keyboard and trackpad are messed up.
Often times I find the cable or the trackpad has suffered the most damage. Unlike the Pro systems, the Airs share a single cable connection to the logic board from the trackpad. You’ll need to pull the battery to inspect (replace) the cable MacBook Air 11" (Late 2010) Trackpad Cable, then I would try replacing the trackpad next MacBook Air 11" (Late 2010) Trackpad following this guide MacBook Air 11" Late 2010 Trackpad Replacement
Replace the trackpad for a MacBook Air 11" A1370 Late 2010 laptop model. Изображение
Продукт
$49.99
Replace the cable that connects the trackpad to the logic board compatible with the Late 2010 11 inch MacBook Air laptop. Изображение
Продукт
$19.99
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I mentioned that using a keyboard and mouse external to the mac doesn't fix the issue and actually does the exact same thing. Could liquid damage or a damaged cable still be the culprit?
Thanks for your answer, I'll try this guide when I'm back at the laptop tomorrow and will begin to check properly for liquid damage
из
For the trackpad, check for any bluetooth mice. That happened with me.
Оценка 0
1 Комментарий:
I tried disabling bluetooth also
из
Добавьте свой ответ
Haydos будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 119
