Faint dark spot on iPad screen from interior "cable burn"
Hi everyone
I have a small faint dark spot on my iPad Air 2 screen. That was unfortunately caused by me accidentally tearing a tiny bit of a cable coating open. A cable like this:
This open cable then burnt/heated up a small spot on the aluminium back panel of the LCD. Which now resulted into this faint dark, barely visible, spot on the screen.
I now covered that open spot up, so it won’t cause any more damage.
It’s hard to capture this on camera, but you can still see it.
My question now is simple:
Can I do anything to fix/smooth out this spot, so it disappears? Without having to replace the whole LCD?
Appreciate all the help, thanks in advance. :-)
New images:
Это хороший вопрос?
3 Комментариев
Obviously u will notice it when the background is white but when it's got an image on or in use would u really even notice that?? If u did want to fix it though it would require a new screen that's if it doesn't just fade on its own... ps sorry what's "ligretto"???
из c9679
Yes true, you can only notice it on a white background, and even then it's barely noticeable. but still, you'll notice it, in person better than on those photos. so yeah that's at least a good thing: if it can't be fixed it's not thaaat big of a deal.
and yeah, definitely not worth replacing the whole lcd over this.
hehehe... I see, on this picture it looks like drugs or something.
Ligtetto is just an old swiss or german card game, similar to UNO. :)
из Ray
The screen is pink around all edges when a white window is open. How can I fix this?
из Serfe may
