Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
Вопросов 20 Показать все
Black screen at start and fan like crazy!
. Hi guys,
Is there anyone who can tell me what to replace or what to do with my MacBook Air 11” which you can turn on and after not even 5 min the screen goes black and the cooling system starts off very loud.
I went to the Apple Store and they said to replace the logic board… But as you know it is very expensive part.
Is there a cheaper solution to fix or do?
Thanks in advance!!
I will attach a pic the last time The laptop lasted on more than 3 min
Это хороший вопрос?
Оценка 0
1 Комментарий
Cool! Thanks a lot for your quick answer!
So if i have to replace the logic board do you
know if i can install a more recent logic board
to upgrade my laptop performance and if yes do you know which ones??
Thanks a lot!
из
Добавить комментарий
Ответов (1)
Выбранное решение
Apple is probably right in this case and you need a board replacement indeed, description points to a board issue. The good news is that the logic boards for that MBA are not expensive anymore, on the contrary, they would cost less than fixing your old one. If you do it yourself, nothing comes cheaper than that:
MacBook Air 11" (Late 2010) 1.4 GHz Logic Board
Replace a 1.4 GHz logic board (motherboard) compatible with the Late 2010 MacBook Air 11" laptop. Fix processing issues like unexpected shutdowns, reboots or water damage. Изображение
Продукт
$49.99
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thanks a lot!
из
@photogreewod You'd have to stick to boards for the A1370 model. I don't know much of the 11.6" i5 boards, but if they're as troublesome as their 13" counterparts, it would be an upgrade I would not recommend. On top of that, the price for the board I linked is rockbottom for a working board and you won't find anything close to that if you look for an upgrade.
из
Hi and again thank you for your answer.
I finally managed to open my laptop (i had no screwdrivers) so i will attach a pic on the first post for what i think it could be an issue and i am absolutely not an expert... but i think and i dont know if you can properly see it from the pic there is something wrong on the circuits on the I/O board... what do you think?? Thank you again for support!
из
Добавьте свой ответ
Gaetano Baiardi будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 107
